If you are going to attempt to detect the bullet using reflected IR, here is some advice:
You need an IR emitter with high radiant intensity. The output of an IR emitter is usually quoted in mW/Sr where Sr is a measure of solid angle. Narrow beam emitters naturally have higher radiant intensity than wide angle emitters. So go for a narrow beam high intensity IR emitter (assuming the bullet path is predictable) such as http://uk.farnell.com/vishay-semiconductor/tsal5100/ir-emitter-2-6v/dp/1469615, not the sort used for TV remote controls. You may wish to use several IR emitters.
For detecting events of this speed, a PIN photodiode is better than a phototransistor. The disadvantage is that it needs more amplification; however the rise and fall times are much faster, around 1us is not hard to obtain.
Shield the detector from extraneous IR. However, scattered light from the muzzle flash may be a serious problem, even if the muzzle flash is well out of sight of the detector.
