Bump switch/sensor question
I'm having problems writing some code that will stop a DC motor when a bump switch/sensor is pressed once. I can get the motor to stop when the switch is HELD down but I really need it to stop when it is only pressed once.
It then needs to wait a number of seconds before starting again.
Anyone have any ideas?
Thanks!
Also, here is my code:
int switchState = digitalRead(2);
int E1 = 5;
int M1 = 4;
int E2 = 6;
int M2 = 7;
pinMode(2, INPUT);
pinMode(M1, OUTPUT);
pinMode(M2, OUTPUT);
digitalWrite(2, HIGH);
int direction = LOW;
int sensorValue = digitalRead(2);
Serial.println(sensorValue);
if (sensorValue == HIGH) {
int value;
for(value = 0; value <= 255; value += 5) {
digitalWrite(M1, direction);
digitalWrite(M2, direction);
analogWrite(E1, value); //PWM Speed Control
analogWrite(E2, value); //PWM Speed Control
else if (sensorValue == LOW){
int value;
analogWrite(E1, LOW); //PWM Speed Control
analogWrite(E2, LOW); //PWM Speed Control
  1. format your code with Cntrl+T in arduino
  2. put it in code brackets
int value;
is the same as
for(int value = 0; value <= 255; value += 5)
  1. int switchState = digitalRead(2); should just be int switchState = 0; for initialization.
  2. in the arduino ide direction (part of int direction = LOW; and other places) is orange colored which means it may already be used my the Arduino as a function or something, change the name a little.
  3. just a tip, you dont have to use a int for reading a digital pin, as it is 0 or 1(LOW or HIGH), cant just use a boolean type instead.
  4. why do you create another value integer and direction integer in this code?:
    int value; //here----
should be like this, i think, if i understand correctly:
  1. now onto your original question :stuck_out_tongue: you may want to try debouncing(http://arduino.cc/it/Tutorial/Debounce), and or interrupt based button press detection:
volatile long lastDebounceTime = 0;   // the last time the interrupt was triggered
#define debounceDelay  50    // the debounce time; decrease if quick button presses are ignored
#define BtnPin 2
  attachInterrupt(BtnPin,FireEvent, RISING);
void FireEvent()
  if ((millis() - lastDebounceTime) > debounceDelay)
    lastDebounceTime = millis();
   //switch was pressed, do stuff like turn off your motor.
hope it helps! feel free to ask more questions.
