format your code with Cntrl+T in arduino
put it in code brackets
int value;
for(value = 0; value <= 255; value += 5)
is the same as
for(int value = 0; value <= 255; value += 5)
int switchState = digitalRead(2); should just be int switchState = 0; for initialization.
in the arduino ide direction (part of int direction = LOW; and other places) is orange colored which means it may already be used my the Arduino as a function or something, change the name a little.
just a tip, you dont have to use a int for reading a digital pin, as it is 0 or 1(LOW or HIGH), cant just use a boolean type instead.
why do you create another value integer and direction integer in this code?:
else if (sensorValue == LOW){
int value; //here----
digitalWrite(M1, direction);
digitalWrite(M2, direction);
analogWrite(E1, LOW); //PWM Speed Control
analogWrite(E2, LOW); //PWM Speed Control
should be like this, i think, if i understand correctly:
- now onto your original question
you may want to try debouncing(http://arduino.cc/it/Tutorial/Debounce), and or interrupt based button press detection:
volatile long lastDebounceTime = 0; // the last time the interrupt was triggered
#define debounceDelay 50 // the debounce time; decrease if quick button presses are ignored
#define BtnPin 2
attachInterrupt(BtnPin,FireEvent, RISING);
void FireEvent()
if ((millis() - lastDebounceTime) > debounceDelay)
lastDebounceTime = millis();
//switch was pressed, do stuff like turn off your motor.
hope it helps! feel free to ask more questions.
