Hello,
I know there are a lot of discussions like this already, I’ve read them over but I still don’t know the solution to my issue. I use a clone USB Asp programmer (fischl compatible), it worked in the past, but today it dropped a verification error during bootloader burning; and all further try to burn the boot loader was failed (see below). I tried different settings and I bricked another 2 Nano dev boards, when the 4th worked. I was happy and as a counter-test, I tried a 5th one that also went wrong. Then I realised the root cause is the faulty (loose) connector to the ICSP. I replaced it and bootloader burning works again. The question is if I can save the 4 boards that I bricked? I hope someone can tell me from the outputs below. I’m afraid the value of the fuses (at least, hfuse and lfuse) is zero.
First run (Tools -> Burn bootloader menu in Arduino 1.8.13):
/home/mr0wl/.arduino15/packages/MiniCore/tools/avrdude/7.2-arduino.1/bin/avrdude -C/home/mr0wl/.arduino15/packages/MiniCore/hardware/avr/3.0.0/avrdude.conf -v -patmega328p -cusbasp -e -Ulock:w:0xff:m -Uefuse:w:0b11111101:m -Uhfuse:w:0xd7:m -Ulfuse:w:0b11110111:m
avrdude: Version 7.2-arduino.1
Copyright the AVRDUDE authors;
see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is /home/mr0wl/.arduino15/packages/MiniCore/hardware/avr/3.0.0/avrdude.conf
User configuration file is /home/mr0wl/.avrduderc
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbasp
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : possible i/o
RETRY pulse : SCK
Serial program mode : yes
Parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Alias Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0x00 0x00
flash 65 10 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
signature 0 0 0 0 no 3 1 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 1 0 0 0 0x00 0x00
Programmer Type : usbasp
Description : USBasp ISP and TPI programmer
avrdude: auto set sck period (because given equals null)
avrdude usbasp_spi_set_sck_period() error: cannot set sck period; please check for usbasp firmware update
avrdude: device signature = 0x1e950f (probably m328p)
avrdude: erasing chip
avrdude: processing -U lock:w:0xff:m
avrdude: reading input file 0xff for lock
with 1 byte in 1 section within [0, 0]
avrdude: writing 1 byte lock ...
avrdude: 1 byte of lock written
avrdude: verifying lock memory against 0xff
avrdude: 1 byte of lock verified
avrdude: processing -U efuse:w:0b11111101:m
avrdude: reading input file 0b11111101 for efuse
avrdude: writing 1 byte efuse ...
avrdude: 1 byte of efuse written
avrdude: verifying efuse memory against 0b11111101
avrdude: 1 byte of efuse verified
avrdude: processing -U hfuse:w:0xd7:m
avrdude: reading input file 0xd7 for hfuse
avrdude: writing 1 byte hfuse ...
***failed;
avrdude: 1 byte of hfuse written
avrdude: verifying hfuse memory against 0xd7
avrdude avr_verify() warning: verification mismatch
device 0x00 != input 0xd7 at addr 0x0000 (error)
avrdude do_op() error: verification mismatch
avrdude done. Thank you.
Further runs:
Using Port : usb
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
avrdude usbasp_spi_program_enable() error: program enable: target does not answer (0x01)
avrdude main() error: initialization failed, rc=-1
- double check the connections and try again
- use -B to set lower the bit clock frequency, e.g. -B 125kHz
- use -F to override this check
The external 16Mhz resonator is given on the Nano board, I also tried to connect a 16MHz crystal to xtal1 pin, with no luck.
Is there anything that I can try or should I give up…?
Thank you!
