Burn bootloader without Arduino board?
I have a USBTiny and I was wondering the best way to program the bootloader onto an ATMega328 without the Arduino board? Can I just use AVRDude? If so, where is the bootloader file? Thanks
Yes. /hardware/bootloaders/*
Even if you don't have the Arduino board you can still use the IDE to upload the bootloader, once you've wired up the IC.
--Phil.
Correct indeed. I'm using the USBtiny and burning bootloaders from the IDE to 168s and 328s chips just mounted to my solderless breadboard. Just needed to wire a crystal and caps up and even let the tiny power the chip, works great.
Lefty
I call avrdude from a Makefile to burn bootloaders. I type
"make" to compile the bootloader and "make isp" to burn
it.
See the bootloader application at http://tinyurl.com/5rfmrz
(* jcl *)
