Burn Bootloader
I used the following instructions to attempt to burn the bootloader:
https://www.arduino.cc/en/tutorial/arduinoISP
Hooked up UNO to UNO as describer and received the following errors
"avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check."
Not very descriptive of what is actually going on I'm afraid. I rechecked connections and they are as in the article. I am using "Arduino as ISP" for the programmer, and Arduino UNO as board. I was able to upload the code without problem to the UNO I am using as the programmer.
One thing i did observe, when I plug in the usb cable into the Programmer UNO the slave UNO doesn't show any lights at all. I would expect the ON light to at least illuminate.
Sure, double check the power and ground connections. If that fails, post some images of your setup.
Ok,
The problem was with the Programmer board. The 5 Volt pin was not putting out 5 Volts. Changed the wire and then was able to burn the boot loader.
So this problem is solved.
