Burn UNO bootloader directly to Duemilanove?
Hi I found my old Duemilanove and wondered if it will work with the UNO bootloader. A search here shows I can basically turn it into a UNO (with minor differences). The question now is: can I burn it directly using just the Duemilanove or will I need to use a programmer/my real UNO/Mega 2560 etc
Thanx
You need an ISP programmer. If you don't own a dedicated programmer you can use a spare Arduino board as an "Arduino as ISP" programmer.
OK thanks Pert. I was starting to suspect that. Just looking at the price of a 328P pre-burnt with UNO. It’s probably simpler to just swap it over and use the old processor in a project. I’m going to order an ISP programmer anyway. They’re cheaper than the processor
My recommendation is to buy a 6 pin USBasp programmer. You can get them for ~$3 USD w/ free shipping if you don't mind waiting for them to come from China. The 10 pin version of the USBasp will work too but you need to get a 10 pin to 6 pin adapter for it. None of my boards use the 10 pin ICSP header so I prefer to just use my 6 pin USBasp since the wider cable and adapter make my 10 pin USBasp more cumbersome to work with.
A dedicated ISP programmer is a very useful tool to have on hand. My USBasp lives on my desk and gets a ton of use!
I already have a cart running up at DX so I've added SKU 916548481 (well under $3). It's a 10 pin but it looks trivial to make a lead for 6 pin. Which programmer do you select for these no-name USB programmers?
I found a Raisonance RLink at work. It has a 2 x 7 pin header. Not sure if they can be adapted for the job. It's not listed in the devices in the IDE.
mega_arduous:
USBasp
mega_arduous:
Those are for STMicroelectronics microcontrollers. Won't work for ATmega328P.
OK. Glad I didn't waste any time looking into the RLink.
Thanks for the help.
All went according to plan. I've relabeled the Duemilanove - "Duno" so I don't forget.
I also have a genuine Nano that never worked from day one. Re-flashing the bootloader fixed that as well.
Well worth the $1.99 investment
I'm glad to hear it worked. Enjoy!
Per
mega_arduous:
I know some people who boatload all 328p based boards as unos
