Burning 328P for 8mhz internal clock erro
Using 1.8.3 IDE, using the official Arduino "Arduino to Breadboard" method.
I downloaded the 1.6 version of the needed files and installed, they show up on IDE restart.
Upload the ArduinoISP sketch to main Uno, fine so far.
Go to burn bootloader (after selecting proper 8mhz board) and I get this:
Arduino: 1.8.3 (Windows 10), Board: "ATmega328 on a breadboard (8 MHz internal clock)"
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
Error while burning bootloader.
What did I do wrong?
I should mention that the controllers are brand new from Mouser, no cheap knockoffs.
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Check the checkbox next to "Show verbose output during: upload
  • Click “OK”
  • Tools > Burn Bootloader
  • After the Burn Bootloader process fails, you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum’s code tags markup to your reply.
  • Press “Ctrl + V”. This will paste the Burn Bootloader output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
Sorry it took so long, didn’t have time to mess with it this weekend.
Requested info:
C:\Users\Dan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\Dan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -PCOM25 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Dan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
         Using Port                    : COM25
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9514 (probably m328)
avrdude done.  Thank you.
Crap, I think I figured it out.
Bought 328-PU chips instead of 328P-PU chips
DOH!
I believe there is a work around , changing the signature in boards.txt while you use this chip.
Google will find it
Yeah, saw that. Wasn't there an issue where I have to change the boards.txt to re-program it every time?
I think it’s just if you change the entry for a given processor, you need to change it back for it to work for the original
Processor.
There may be better solutions
Don't modify boards.txt unless you are developing your own hardware package. You just set a trap for yourself down the road when you forget the modifications, or upgrade the IDE and lose your modifications and forget what they were.
Install the MiniCore package, which supports minimal atmega328/328p/328pb and all the smaller-flash versions of those parts, with all clock options except the super-exotic ones, with bootloaders for all of them. GitHub - MCUdude/MiniCore: Arduino hardware package for ATmega8, ATmega48, ATmega88, ATmega168, ATmega328 and ATmega328PB
