Burning arduino pro mini bootloader onto a new chip/
Hi there. I have been attempting to create a breadboard arduino and have finally managed to get a sketch onto my atmega238p by following this tutorial.
The problem is that I want to run at 8mhz with an external crystal (arduino mini) but there is no option for this in the board programmer software. there are 2 options of either 8mhz internal or 16mhz external. I have tried uploading the bootloader i want using the built in function in the arduino software but it only ever says 'error while burning bootloader (there is minimal activity on the tx/rx lights, just a single blink and then nothing).Am I missing something in the software or does it simply not have the functionality of burning the required bootloader? Any advise would me much appreciated. thanks.
ps. I am using an smd chip(broken out), im not sure if this is irrelevant information or not.
gonadgranny:
The easiest solution is to use MiniCore:
It has an external 8 MHz clock option.
gonadgranny:
Most likely there is something wrong with your circuit. Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Tools > Burn Bootloader
  • After the process fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
Hi, I will have a look at the software, thanks for the suggestion.
Here is the output:
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/danny/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done.  Thank you.
Error while burning bootloader.
What type of ISP programmer are you using? Is it an Arduino board like in the tutorial?
pert:
that was done using an FTDI programmer. i am able to upload sketches this way but the bootloader generates that message. i just put the chip back in the original circuit connected to an arduino nano and tried burning it this way but i get the same message:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
         Using Port                    : usb
option enabled in File -> Preferences.
i am still able to talk to the chip using nick's programmer sketch though...
Atmega chip programmer.
Written by Nick Gammon.
Version 1.38
Compiled on Aug 31 2018 at 13:36:05 with Arduino IDE 10805.
Attempting to enter ICSP programming mode ...
Entered programming mode OK.
Signature = 0x1E 0x95 0x0F
Processor = ATmega328P
Flash memory size = 32768 bytes.
LFuse = 0xFF
HFuse = 0xDE
EFuse = 0xFD
Lock byte = 0xEF
Clock calibration = 0x8A
Type 'L' to use Lilypad (8 MHz) loader, or 'U' for Uno (16 MHz) loader ...
Ok so I just tried the 'burn bootloader' on my arduno uno(chinese preassembled clone) and got the same problem(have tried using the standard arduino uni core and also the core you recommended, neither work). does this suggest that its something other than the wiring?
gonadgranny:
It's not possible to burn bootloader in the Arduino IDE using an FTDI. You need to use an ISP programmer. If you don't own a dedicated ISP programmer then you can use a spare Arduino as an "Arduino as ISP" programmer. You can do this with the Nano connected to your target board as shown in the Gammon tutorial:
Supposedly it is possible to burn the bootloader using an FTDI FT232 via the command line but it's very slow. I've never tried it and I would recommend that you don't mess with that since you're already having enough trouble without adding a bunch of extra complexity.
pert:
Yes i certianly dont want to complicate things further. I have tried following those instructions and now I get this error:
Arduino: 1.8.5 (Mac OS X), Board: "ATmega328, Yes, 328P / 328PA, 2.7v, Disabled (default), 8 MHz external"
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/danny/Library/Arduino15/packages/MiniCore/hardware/avr/2.0.1/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.wchusbserial1420 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0xfd:m -Uhfuse:w:0xd6:m -Ulfuse:w:0b11110111:m
         System wide configuration file is "/Users/danny/Library/Arduino15/packages/MiniCore/hardware/avr/2.0.1/avrdude.conf"
         Using Port                    : /dev/cu.wchusbserial1420
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
         Hardware Version: -1451085996
         Firmware Version: -1073745512.444305
         Topcard         : STK502
         Vtarget         : 1.8 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
this check.
A 10uF capacitor between Reset and Gnd on the "Arduino as ISP", stripe toward Gnd will usually fix this problem of the Arduino used as Programmer getting reset.
kprims:
kprims, do you mean to put a capacitor on from reset to ground on the programmer arduino (not the one being programmed)? thanks/.
Yes, he meant the programmer.
