Hello, I am having som problems with my arduino. I recently was editing some code of one of my projects and changed the output pins to 0 and 1 (RX and TX), because I thought they would work like any other. I found out that they are a little different, but that should only matter when you are having serial communication, which I do not have - I just used "digitalWrite". After I changed the pins to RX and TX I could not upload any code to my arduino. It reports the following error.
Archiving built core (caching) in: C:\Users\SIMONF~1\AppData\Local\Temp\arduino_cache_329785\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\SIMONF~1\AppData\Local\Temp\arduino_build_165355/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe1
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe1
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe1
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe1
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe1
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I did not save the exact code, but it was almost simular to this one:
int DirPin = 1; //Direction pin
int StepPin = 2; //Stepper pin
//TID
long sec = 1000L;
long minute = (sec*60);
long hour = (minute*60);
pinMode(DirPin, OUTPUT);
pinMode(StepPin, OUTPUT);
digitalWrite(DirPin, HIGH); //Defines direction of rotation
digitalWrite(StepPin, LOW);
unsigned long Time = millis();
if (Time > (5*sec)) //Defines when the motor starts after arduino powers on
digitalWrite(StepPin, HIGH);
delayMicroseconds(500);
I did some research and figured it might be the bootloader. So i tried to burn the bootloader with another arduino (which works). I connected the arduinos like in the guide
with the 10 uF capacitor between reset and ground of the working arduino. I am sure the rest of the wiring is correct.
When doing this i get the following error.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM6 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
Using Port : COM6
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Error while burning bootloader.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0xff0000
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
Both of the arduinos have the ATMEGA382P-PU chpis.
Have I fried the chip of the arduino by using RX and TX?
Have I fried the chip by using RX and TX?
Kind regards Simon
