burning bootloader errors using arduinoisp
I am trying to set an atmega328p to use its internal oscillator, firstly I downloaded and extracted to the "hardware" file the zip as instructed in the tutorial, all went well. When I started using the IDE to compile and upload any sketches I now get a warning that reads....Warning: Board Breadboard Arduino: Avr: atmega 328bb doesn't define a 'build board' preference. Auto-Set to: AVR_ATMEGA328BB...…….I get this warning now every time I use the IDE regardless of sketch. I now went to burn the bootloader and again followed the tutorial (and may others on u-tube) and I always get the same error :-Arduino: 1.8.5 (Windows 10), Board: "ATmega328 on a breadboard (8 MHz internal clock)"
avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check.
Error while burning bootloader.
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
I have tried re-wiring several times, check supply and gnd, I have "buzzed out" my cables tried swoping chips from host to target (both run blink ok) and many other things. I un-installed the IDE and deleted the hardware file and the Arduino directory and did a clean install. I found after completing this the warning still came up which I don't understand as it was a new install I then downloaded the correct zip to the hardware file I had newly created in the sketch folder tried to burn bootloader and got the same error as above. I also don't no what "or use -F to override this check" means? Please can you help me ?
Hello there!
Do you have all of the wiring correct? And do you have a 10uF capacitor between reset and ground on your programmer board?
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Tools > Burn Bootloader
  • After the process fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
hi this is it
[/codArduino: 1.8.5 (Windows 10), Board: "ATmega328 on a breadboard (8 MHz internal clock)"
C:\Users\andy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\andy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\andy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.03s
         this check.
avrdude done.  Thank you.
e]
Could the chip have previously been configured to use a crystal?
Hi this is a distinct possibility, I only have one at the moment (waiting for eBay) if so, would this cause the problem?...…... and does this mean that most tutorials Assume you have a virgin device?
thanks
