Burning bootloader not working
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\.\COM3": Access is denied.
Failed uploading: uploading error: exit status 1
i tried with many different stuff and i tried the reset button and connected the gnd and reset pins. i was not uploading my code becuse it didnt work i was uploading the blink example
For informed help, please read and follow the instructions in the "How to get the best out of this forum" post, linked at the head of every forum category.
Hi! Welcome do the Forum.
+1 to
Meanwhile, is there any specific reason why you want to "burn the bootloader"? Even Uno clone boards already have the bootloader into them off the shelf, together with the blink sketch (blinks the builtin LED in a 1 sec on/ 1 sec off pattern when you power the board).
i want to get a custom firmware on it and i am using xloader but it keeps failing and no matter what i do i cant get it to dfu, instead i wont be able to acces port
The first thing I'd check is whether you have something else accessing that port. Serial monitor, serial plotter, another terminal program...
That's not the expected output of burning a bootloader but indicates a compilation of a sketch.
So please tell us if you're trying to burn a bootloader or if you're trying to upload a sketch.
  1. Which board? What is the serial-to-usb converter on that board?
  2. Is COM3 indeed the correct port? Does it disappear from the IDE and Windows device manager if you disconnect the board?
  3. Which version of the IDE?
how
Oh my goodness. If you're not even willing to think, you're doomed. Good-bye.
what do you mean i am new i was not opening any other app that controlls the arduino and when i press, hold press the reset button 2 times por do the sa,e but with wires nothing works
