Burning bootloader on atmega328p using mega2560
Hello,
can i burn bootloader on atmega328p using mega2560 board or do i need uno board?
No you can use a Mega, just need to identify the correct pins to use.
I successfully did it.
Here is the tutorial if someone needs it:
But in arduinoISP example you must change pins, it is configured for UNO board.
Here is pin config:
UNO MEGA
slave reset 10 53
M0SI 11 51
MIS0 12 50
SCK 13 52
