I have a RobotDyn Mega 2560 ETH with MicroSD card reader and POE active. The board has a W5500 and SDcard attached and the possibility to attach an ESP-01.
I want to burn the bootloader with Arduino 1.8.13 and the mega2560 connected to my MacBook with MacOs Catalina 10.15.7
I use:
Tools > Selected boar: Mega 2560
Tools > Port: /dev/cu.SLAB_USBtoUART
Tools >Programmer: Arduino as ISP
Tools > Burn Bootloader
But I get
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
What should I do with the hardware to prepare the board for burning bootloader? With the W5500, SDcard and ESP-01 there are already some connections soldered, see the attached picture of the back of my board. On this forum I see a lot of people using another arduino. But I just want to do it with my MacBook, that way it looks the easy way for a beginner like me.
do you have a capacitor on reset pin of the programmer Arduino to prevent its reset?
(I suspect you didn't setup an Arduino as ISP at all)
and you should select "Arduino Mega 2560 (Optiboot)" in Tools menu.
I read the page you linked, I bought a capacitor (got it today), build the programmer/target setup and burned the optiboot.
I think the burning works because I can only upload new sketches when I select board: "Arduino Mega 2560 (Optiboot)" and when I select the old board: "Arduino Mega or Mega 2560" is cannot connect.
But the problem with ArduinoOTA still exists. I can see the board appears with an IP in Arduino IDE. But the password does not work. I have to give the password but it won't work and I get "Resetting the board
Failed to reset the board, upload failed".
What goes wrong? Do I have to check if I burned the bootloader correctly? And how do I do it?
The output with verbose mode:
Sketch uses 22752 bytes (8%) of program storage space. Maximum is 261120 bytes.
Global variables use 1368 bytes (16%) of dynamic memory, leaving 6824 bytes for local variables. Maximum is 8192 bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/arduinoOTA -address 192.168.178.89 -port {upload.network.port} -sketch /var/folders/3w/p74x5s317vjf33g5l9gz0d_w0000gn/T/arduino_build_944747/OTEthernet.ino.hex -upload {upload.network.endpoint_upload} -sync {upload.network.endpoint_sync} -reset {upload.network.endpoint_reset} -sync_exp {upload.network.sync_return}
Resetting the board
Resetting the board
Juraj:
the command is not right. copy platform.local.txt from extras/avr folder in library next platform.txt of AVR boards package
/Users/Mine/Documents/Arduino/libraries/ArduinoOTA/extras/avr/platform.local.txt
to
/Users/Mine/Documents/Arduino/hardware/my_boards/avr/platform.txt
I am sorry. I do not understand your short sentences immediately.
You mean I have to copy the file from extras/avr
1.) to my_boards/avr/ directory like (in the same directory is next to??)
/Users/Mine/Documents/Arduino/hardware/my_boards/avr/platform.local.txt
and 2.) to official AVR boards as platform.txt (not .local.txt) where also preferences.txt is and for me that would be:
/Users/Mine/Library/Arduino15/platform.txt
Or do you mean the subdirectory packages folder
/Users/Mine/Library/Arduino15/packages/platform.txt
But that's not working either. And the directory Arduino15 is quite empty. I do not see AVR/Mega etc. I only see ESP8266.
So I guess I am in the wrong directory? Could you explain to me in more detail in what directory I have to put the platform.local.txt? There should also be a platform.txt located? and it must not be your My_boards directory?
To use remote upload from IDE with SDStorage or InternalStorage, copy platform.local.txt from extras/avr folder, next to platform.txt in the boards package used (Arduino-avr or MCUdude packages). You can find the location of boards packages in Arduino IDE Preferences as the location of the preferences.txt file at the bottom of the Preferences dialog. It is clickable and opens the folder. There find the boards package in packages folder.
Thanking you for your patience with me. I have read your GitHub page more than ten times. It is very informative. But I am suffering: I cannot find the the mentioned destination for platform.local.txt
Yes, that is this file: /Users/Mine/Documents/Arduino/libraries/ArduinoOTA/extras/avr/platform.local.txt
next to platform.txt in the boards package used (Arduino-avr or MCUdude packages).You can find the location of boards packages in Arduino IDE Preferences as the location of the preferences.txt file at the bottom of the Preferences dialog. It is clickable and opens the folder. There find the boards package in packages folder.
I can find my preferences.txt file at /Users/Mine/Library/Arduino15/preferences.txt
But after that I do not understand where to look.
It suggest that there is platform.txt at /Users/Mine/Library/Arduino15/ but there is no platform.txt
It suggest that it is in the package directory, so at Users/Mine/Library/Arduino15/packages. But there is no platform.txt
My packages directory contains only the directory ESP8266/
Users/Mine/Library/Arduino15/packages/ESP8266/ contains 2 subdirectories (hardware and tools). If I continue I can find
/Users/Mine/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/platform.txt
But where do I have to find the AVRArduino-avr or MCUdude packages? It is not at Users/Mine/Library/Arduino15/
Is it different on MacOS? Or I am too old for this?
Juraj:
it looks like you use the AVR boards package bundled with IDE. search for platform.txt in IDE installation folder
I had to show content at /Applications/Arduino.app
Afterwards it was visible at /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Now it works. Many thanks!!!
Do you know why mDNS sometimes works and sometimes does not work with the standard OTEthernet sketch? I did not install other libraries but discovered that the name for OTA also works as name.local in the webbrowser.
MacQwerty:
the implementation of mDNS in the library is very simple (it was not coded by me. it is a code inherited from the original Arduino library for SAMD)
