burning bootloader to Nano?
hi, I have a couple of Arduino Nano without bootloaders..
My first option is to burn the bootloader from Arduino. Here's how things are set:
  • Nano is powered by USB
  • AVR MKII connected correctly (green led)
  • "Arduino Diacimila" selected from "Tools/Board"
Here's what I see in the debug pane, any ideas? Cheers...
hardware/tools/avr/bin/avrdude -Chardware/tools/avr/etc/avrdude.conf -v -v -v -v -pm168 -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0x00:m -Uhfuse:w:0xdd:m -Ulfuse:w:0xff:m
avrdude: Version 5.4-arduino, compiled on Oct  9 2007 at 11:20:31
System wide configuration file is "hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/tobie/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 0000B0010049
AVR Part              : ATMEGA168
Chip Erase delay      : 9000 us
PAGEL                 : PD7
BS2                   : PC2
RESET disposition     : dedicated
RETRY pulse           : SCK
serial program mode   : yes
parallel program mode : yes
Timeout               : 200
StabDelay             : 100
CmdexeDelay           : 25
SyncLoops             : 32
ByteDelay             : 0
PollIndex             : 3
PollValue             : 0x53
Memory Detail         :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no        512    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     16384  128    128  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
Programmer Type : STK500V2
Description     : Atmel STK500 Version 2.x firmware
Programmer Model: AVRISP mkII
avrdude: Sent: . [03] . [90]
avrdude: Recv: . [03] . [00] . [01]
avrdude: Sent: . [03] . [91]
avrdude: Sent: . [03] . [92]
Hardware Version: 1
Firmware Version: 1.01
avrdude: Sent: . [03] . [94]
avrdude: Recv: . [03] . [00] / [2f]
Vtarget         : 4.7 V
avrdude: Sent: . [03] . [98]
avrdude: Recv: . [03] . [00] . [07]
SCK period      : 10.37 us
avrdude: Sent: . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] . [ff] . [bf]
avrdude: Recv: . [10] . [c0]
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override this check.
avrdude: Sent: . [11] . [01] . [01]
avrdude: Recv: . [11] . [00]
avrdude done.  Thank you.
I'm not sure how are these two get slipped. We are doing 100% testing on all of the boards. You can send them back and we can program them for you at no charge. Please contact us support@gravitech.us for the RMA#.
hi Gravitech, thanks...
