I have an AVRISP MKII and Arduino Diecimila board. I tried to burn a few fresh Atmega168's so that I could make projects with them and ran into some problems.
My first problem is when I try to burn them from Arduino 10 in Windows XP, I get an error that it "AVR_dude" can't find the 'usb' port for the AVRISP MKII. Is there anything I need to set to make this work? I have both the AVRISP and my Arduino plugged into USB cables.
When I try to burn the bootloader from AVR Studio 4, it says that the bootloader won't fit the chip..
So I put the original Arduino Atmega168 chip in and read it in. The file read from the 'Flash' is larger than the bootloader itself.. and if I do a file compare with "Beyond Compare 2", there is a section of code near the middle which matches the bootloader file but still a good deal of data above and below that. There was also code in the 'eeprom' section which I think was my current sketch. I read that in too. I was able to take the downloaded flash and eeprom files and burn them to 2 other Atmega168's which now work when used in my Arduino board.
