My atmega 16u2 on my Uno is out of order and will not upload any sketches.If I use an external programer http://arduino.cc/en/Hacking/Programmer
via the icsp header next to the atmega 328, will this broken chip affect my programing, or I just need the atemga 328 cip to be programed?
The topic is quite urgent.Thanks in advance!
16U2 connects to Rx/Tx.
ICSP connects to SPI pins.
You should be able to program via ICSP without issue.
Good, but my 16u2 is NOT working.It has been burnt I believe...So can I use the icsp to program the 328 without using the 16u2 in any way???
I believe so. As I said, different control lines.
Tsoni:
That link is very old information and should really not be used. The current IDE makes it quite easier to directly burn sketches from the IDE without having to use the normal arduino board's serial link. You will of course need a hardware ICSP programmer but that can be just another arduino board loaded with the arduinoISP sketch that then wires to your target board via the SPI pins. In the IDE's tools menu you must first select the board type of your target board and select the hardware programmer you will be using. Then in the IDE's file menu there is a 'upload using programmer' option that will compile the sketch in the IDE edit window and upload it via your programmer to the target board.
Lefty
Thanks!Just ordered another arduino- this time a nano, but not an original one though.I hope it will work and then I will use it to upload sketches to the broken uno.I will tell if it worked in 2-3 weeks.
Tsoni:
It will work, it's just a matter of getting all the wiring and detail steps correctly done.
Lefty
