Bus Fault after linking dashboard variables
I have and Uno R4 that will run my sketch and connect to the cloud. However after I create a dashboard and assign the desired variables to a dashboard widget the Uno then gets a bus fault. I attached my code, as well as the fault from the serial monitor below. Any ideas or suggestions would be appreciated. I have tried 2 different Arduinos and have the same results on both.
Also, if I do not run the cloud update the sketch runs fine on the Arduino as well.
#include "arduino_secrets.h"
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/502ad697-8c61-493c-8f89-5f7cdbcc3cd1
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  float xAxis_HomePosmm;
  float xAxis_Indexmm;
  float xAxis_MoveToPosmm;
  float xAxis_Posmm;
  float xAxis_RPM;
  float yAxis_HomePosmm;
  float yAxis_Indexmm;
  float yAxis_MoveToPosmm;
  float yAxis_Posmm;
  float yAxis_RPM;
  float zAxis_HomePosmm;
  float zAxis_Indexmm;
  float zAxis_MoveToPosmm;
  float zAxis_Posmm;
  float zAxis_RPM;
  int cloudUpdateRate;
  int scanRateMS;
  int wifiSignalStrength;
  int xAxis_Accel;
  int xAxis_Index;
  int xAxis_MaxSpeed;
  int xAxis_MoveToPos;
  int xAxis_Pos;
  int xAxis_PulsesPerRev;
  int xAxis_SetPos;
  int yAxis_Accel;
  int yAxis_Index;
  int yAxis_MaxSpeed;
  int yAxis_MoveToPos;
  int yAxis_Pos;
  int yAxis_PulsesPerRev;
  int yAxis_SetPos;
  int zAxis_Accel;
  int zAxis_Index;
  int zAxis_MaxSpeed;
  int zAxis_MoveToPos;
  int zAxis_Pos;
  int zAxis_PulsesPerRev;
  int zAxis_SetPos;
  bool heartbeat;
  bool stopMotionPB;
  bool xAxis_Alarm;
  bool xAxis_EnablePB;
  bool xAxis_IndexNegPB;
  bool xAxis_IndexPosPB;
  bool xAxis_InPosition;
  bool xAxis_MoveToPB;
  bool xAxis_SetPosPB;
  bool yAxis_Alarm;
  bool yAxis_EnablePB;
  bool yAxis_IndexNegPB;
  bool yAxis_IndexPosPB;
  bool yAxis_InPosition;
  bool yAxis_MoveToPB;
  bool yAxis_SetPosPB;
  bool zAxis_Alarm;
  bool zAxis_EnablePB;
  bool zAxis_IndexNegPB;
  bool zAxis_IndexPosPB;
  bool zAxis_InPosition;
  bool zAxis_MoveToPB;
  bool zAxis_SetPosPB;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <AccelStepper.h>
//Define Axes
AccelStepper XAxis(1,2,3);
AccelStepper YAxis(1,7,8);
AccelStepper ZAxis(1,12,13);
bool BlockCloudUpdate = false;
int CloudUpdatePrevMS = 0;
int CloudDisconnectedMS = 0;
int CloudClock = 0;
bool OkToRestart = true;
int ScanRatePrevMS = 0;
int HeartbeatStartTime = 0;
int XAxisLead = 165; //165mm per Revolution
int YAxisLead = 10; //10mm per Revolution
int ZAxisLead = 165; // 165mm per Revolution
int XAxis_CmdPos = 0;
int YAxis_CmdPos = 0;
int ZAxis_CmdPos = 0;
int XAxis_HomePos = 0;
int YAxis_HomePos = 0;
int ZAxis_HomePos = 0;
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(4);
  ArduinoCloud.printDebugInfo();
  //XAxis Stepper Setup
  pinMode(2, OUTPUT); //Stepper Pulse Pin
  pinMode(3, OUTPUT); //Stepper Direction Pin
  pinMode(4, INPUT_PULLUP); //Stepper Drive Alarm Status
  pinMode(5, OUTPUT); //Stepper Enable
  pinMode(6, INPUT_PULLUP); // Stepper in Position
  XAxis.setMinPulseWidth(30);
  XAxis.setEnablePin(5);
  XAxis.disableOutputs();
  //YAxis Stepper Setup
  pinMode(7, OUTPUT); //Stepper Pulse Pin
  pinMode(8, OUTPUT); //Stepper Direction Pin
  pinMode(9, INPUT_PULLUP); //Stepper Drive Alarm Status
  pinMode(10, OUTPUT); //Stepper Enable
  pinMode(11, INPUT_PULLUP); // Stepper in Position
  XAxis.setEnablePin(10);
  //ZAxis Stepper Setup
  pinMode(12, OUTPUT); //Stepper Pulse Pin
  pinMode(13, OUTPUT); //Stepper Direction Pin
  pinMode(A3, INPUT_PULLUP); //Stepper Drive Alarm Status
  pinMode(A1, OUTPUT); // Stepper Enable
  pinMode(A2, INPUT_PULLUP); // Stepper in Position
  ZAxis.setMinPulseWidth(30);
  ZAxis.setEnablePin(A1);
  ZAxis.disableOutputs();
  ZAxis.setPinsInverted(true, false, false); //Set Direction to be Positive in +Z Direction
  Serial.println("Loop Started");
  //Cloud Update Logic
  if (!BlockCloudUpdate) {
    CloudUpdateLogic();
  //Scan Rate and Heart Beat Logic
  ScanRateLogic();
  //Call Stepper Functions
  XAxisStepperLogic();
  YAxisStepperLogic();
  ZAxisStepperLogic();
  Serial.println("Loop Completed");
/*Cloud Update Logic*/
void  CloudUpdateLogic() {
  Serial.println("Cloud Update Started");
  cloudUpdateRate = 500;
  //Cloud Update
  if ((millis() - CloudUpdatePrevMS >= cloudUpdateRate)) {
    Serial.println("CU1");
    ArduinoCloud.update();
    //Serial.println("CU2");
    CloudUpdatePrevMS = millis();
    //Serial.println("CU3");
  Serial.println("CU4");
  if (ArduinoCloud.connected()) {
    CloudClock = ArduinoCloud.getLocalTime();
    wifiSignalStrength = WiFi.RSSI();
  Serial.println("CU5");
  //Cloud Disconnected then Auto Reset
    CloudDisconnectedMS = millis();
    if ((millis() - CloudDisconnectedMS) > (300000) and OkToRestart) {
      NVIC_SystemReset();
  //Serial.println("CU6");
//ScanRate and Heartbeat Logic
void  ScanRateLogic() {
  //Heartbeat
  if (millis() - HeartbeatStartTime > 1000) {
    if (heartbeat) {
      heartbeat = false;
    else {
      heartbeat = true;
    HeartbeatStartTime = millis();
  //Scan Rate
  scanRateMS = millis() - ScanRatePrevMS;
  ScanRatePrevMS = millis();
//XAxis Stepper Logic
void  XAxisStepperLogic() {
  //Monitor Alarm Bit of Stepper Driver
  //High = No Alarm, Low = Alarm
  xAxis_Alarm = digitalRead(4);
  //Monitor In Position of Stepper Driver
  xAxis_InPosition = digitalRead(6);
  //XAxis Positional Data
  xAxis_Pos = XAxis.currentPosition();
  xAxis_Posmm = (float(XAxis.currentPosition()) / float(xAxis_PulsesPerRev) * float(XAxisLead));
  if (xAxis_SetPosPB) {
    XAxis.setCurrentPosition(xAxis_SetPos);
  xAxis_RPM = (xAxis_MaxSpeed * 60) / xAxis_PulsesPerRev;
  //XAxis Run
  while(XAxis.distanceToGo() != 0 && xAxis_Alarm == false){
    XAxis.run();
  //Stepper 1 Moves
  if (stopMotionPB) {
    XAxis.stop();
  //Block Cloud Update While Running
  if (XAxis.isRunning()) {
    BlockCloudUpdate = true;
  else {
//YAxis Stepper Logic
void  YAxisStepperLogic() {
  yAxis_Alarm = digitalRead(4);
  yAxis_InPosition = digitalRead(6);
  //YAxis Positional Data
  yAxis_Pos = YAxis.currentPosition();
  yAxis_Posmm = (float(YAxis.currentPosition()) / float(yAxis_PulsesPerRev) * float(YAxisLead));
  if (yAxis_SetPosPB) {
    YAxis.setCurrentPosition(yAxis_SetPos);
  yAxis_RPM = (yAxis_MaxSpeed * 60) / yAxis_PulsesPerRev;
  //YAxis Run
  while(YAxis.distanceToGo() != 0 && yAxis_Alarm == false){
    YAxis.run();
  //Stepper 1 Moves
  if (stopMotionPB) {
    YAxis.stop();
  if (YAxis.isRunning()) {
  else {
//ZAxis Stepper Logic
void  ZAxisStepperLogic() {
  zAxis_Alarm = digitalRead(A3);
  zAxis_InPosition = digitalRead(A2);
  //ZAxis Positional Data
  zAxis_Pos = ZAxis.currentPosition();
  zAxis_Posmm = (float(ZAxis.currentPosition()) / float(zAxis_PulsesPerRev) * float(ZAxisLead));
  if (zAxis_SetPosPB) {
    ZAxis.setCurrentPosition(zAxis_SetPos);
  zAxis_RPM = (zAxis_MaxSpeed * 60) / zAxis_PulsesPerRev;
  //ZAxis Run
  while(ZAxis.distanceToGo() != 0 && zAxis_Alarm == false){
    ZAxis.run();
  //Stepper 1 Moves
  if (stopMotionPB) {
    ZAxis.stop();
  if (ZAxis.isRunning()) {
  else {
  //Position Conversions from mm to steps
  ZAxis_HomePos = float(zAxis_HomePosmm) * (float(zAxis_PulsesPerRev) / float(ZAxisLead));
  Since CloudUpdateRate is READ_WRITE variable, onCloudUpdateRateChange() is
  executed every time a new value is received from IoT Cloud.
void onCloudUpdateRateChange()  {
  // Add your code here to act upon CloudUpdateRate change
  Since WifiSignalStrength is READ_WRITE variable, onWifiSignalStrengthChange() is
void onWifiSignalStrengthChange()  {
  // Add your code here to act upon WifiSignalStrength change
  Since ScanRateMS is READ_WRITE variable, onScanRateMSChange() is
void onScanRateMSChange()  {
  // Add your code here to act upon ScanRateMS change
  Since XAxisEnablePB is READ_WRITE variable, onXAxisEnablePBChange() is
void onXAxisEnablePBChange()  {
  // Add your code here to act upon XAxisEnablePB change
  if (!xAxis_EnablePB){
    XAxis.enableOutputs();
    //digitalWrite(5, HIGH);
  if (xAxis_EnablePB){
    //digitalWrite(5, LOW);
  Since XAxisIndexNegPB is READ_WRITE variable, onXAxisIndexNegPBChange() is
void onXAxisIndexNegPBChange()  {
  // Add your code here to act upon XAxisIndexNegPB change
  if (xAxis_IndexNegPB) {
    XAxis.move(-1 * xAxis_Index);
  Since XAxisIndexPosPB is READ_WRITE variable, onXAxisIndexPosPBChange() is
void onXAxisIndexPosPBChange()  {
  // Add your code here to act upon XAxisIndexPosPB change
  if (xAxis_IndexPosPB) {
    XAxis.move(xAxis_Index);
  Since XAxisMoveToPB is READ_WRITE variable, onXAxisMoveToPBChange() is
void onXAxisMoveToPBChange()  {
  // Add your code here to act upon XAxisMoveToPB change
  XAxis.moveTo(xAxis_MoveToPos);
  Since XAxisSetPosPB is READ_WRITE variable, onXAxisSetPosPBChange() is
void onXAxisSetPosPBChange()  {
  // Add your code here to act upon XAxisSetPosPB change
  Since XAxisAccel is READ_WRITE variable, onXAxisAccelChange() is
void onXAxisAccelChange()  {
  // Add your code here to act upon XAxisAccel change
  XAxis.setAcceleration(xAxis_Accel);
  Since XAxisIndex is READ_WRITE variable, onXAxisIndexChange() is
void onXAxisIndexChange()  {
  // Add your code here to act upon XAxisIndex change
  xAxis_Indexmm = float(xAxis_Index) / float(xAxis_PulsesPerRev) * float(XAxisLead);
  Since XAxisMaxSpeed is READ_WRITE variable, onXAxisMaxSpeedChange() is
void onXAxisMaxSpeedChange()  {
  // Add your code here to act upon XAxisMaxSpeed change
  XAxis.setMaxSpeed(xAxis_MaxSpeed);
  Since XAxisMoveToPos is READ_WRITE variable, onXAxisMoveToPosChange() is
void onXAxisMoveToPosChange()  {
  // Add your code here to act upon XAxisMoveToPos change
  xAxis_MoveToPosmm = float(xAxis_MoveToPos) / float(xAxis_PulsesPerRev) * float(XAxisLead);
  Since XAxisPulsesPerRev is READ_WRITE variable, onXAxisPulsesPerRevChange() is
void onXAxisPulsesPerRevChange()  {
  // Add your code here to act upon XAxisPulsesPerRev change
  Since XAxisSetPos is READ_WRITE variable, onXAxisSetPosChange() is
void onXAxisSetPosChange()  {
  // Add your code here to act upon XAxisSetPos change
  Since XAxisHomePosmm is READ_WRITE variable, onXAxisHomePosmmChange() is
void onXAxisHomePosmmChange()  {
  // Add your code here to act upon XAxisHomePosmm change
  XAxis_HomePos = float(xAxis_HomePosmm) * (float(xAxis_PulsesPerRev) / float(XAxisLead));
  Since XAxisIndexmm is READ_WRITE variable, onXAxisIndexmmChange() is
void onXAxisIndexmmChange()  {
  // Add your code here to act upon XAxisIndexmm change
  xAxis_Index = float(xAxis_Indexmm) * (float(xAxis_PulsesPerRev) / float(XAxisLead));
  Since XAxisMoveToPosmm is READ_WRITE variable, onXAxisMoveToPosmmChange() is
void onXAxisMoveToPosmmChange()  {
  // Add your code here to act upon XAxisMoveToPosmm change
  xAxis_MoveToPos = float(xAxis_MoveToPosmm) * (float(xAxis_PulsesPerRev) / float(XAxisLead));
  Since XAxisRPM is READ_WRITE variable, onXAxisRPMChange() is
void onXAxisRPMChange()  {
  // Add your code here to act upon XAxisRPM change
  Since StopMotionPB is READ_WRITE variable, onStopMotionPBChange() is
void onStopMotionPBChange()  {
  // Add your code here to act upon StopMotionPB change
  Since YAxisEnablePB is READ_WRITE variable, onYAxisEnablePBChange() is
void onYAxisEnablePBChange()  {
  // Add your code here to act upon YAxisEnablePB change
  if (!yAxis_EnablePB){
    YAxis.enableOutputs();
  if (yAxis_EnablePB){
    YAxis.disableOutputs();
  Since YAxisIndexNegPB is READ_WRITE variable, onYAxisIndexNegPBChange() is
void onYAxisIndexNegPBChange()  {
  // Add your code here to act upon YAxisIndexNegPB change
  if (yAxis_IndexNegPB) {
    YAxis.move(-1 * yAxis_Index);
  Since YAxisIndexPosPB is READ_WRITE variable, onYAxisIndexPosPBChange() is
void onYAxisIndexPosPBChange()  {
  // Add your code here to act upon YAxisIndexPosPB change
  if (yAxis_IndexPosPB) {
    YAxis.move(yAxis_Index);
  Since YAxisMoveToPB is READ_WRITE variable, onYAxisMoveToPBChange() is
void onYAxisMoveToPBChange()  {
  // Add your code here to act upon YAxisMoveToPB change
  YAxis.moveTo(yAxis_MoveToPos);
  Since YAxisSetPosPB is READ_WRITE variable, onYAxisSetPosPBChange() is
void onYAxisSetPosPBChange()  {
  // Add your code here to act upon YAxisSetPosPB change
  Since YAxisAccel is READ_WRITE variable, onYAxisAccelChange() is
void onYAxisAccelChange()  {
  // Add your code here to act upon YAxisAccel change
  YAxis.setAcceleration(yAxis_Accel);
  Since YAxisIndex is READ_WRITE variable, onYAxisIndexChange() is
void onYAxisIndexChange()  {
  // Add your code here to act upon YAxisIndex change
  yAxis_Indexmm = float(yAxis_Index) / float(yAxis_PulsesPerRev) * float(YAxisLead);
  Since YAxisMaxSpeed is READ_WRITE variable, onYAxisMaxSpeedChange() is
void onYAxisMaxSpeedChange()  {
  // Add your code here to act upon YAxisMaxSpeed change
  YAxis.setMaxSpeed(yAxis_MaxSpeed);
  Since YAxisMoveToPos is READ_WRITE variable, onYAxisMoveToPosChange() is
void onYAxisMoveToPosChange()  {
  // Add your code here to act upon YAxisMoveToPos change
  yAxis_MoveToPosmm = float(yAxis_MoveToPos) / float(yAxis_PulsesPerRev) * float(YAxisLead);
  Since YAxisPulsesPerRev is READ_WRITE variable, onYAxisPulsesPerRevChange() is
void onYAxisPulsesPerRevChange()  {
  // Add your code here to act upon YAxisPulsesPerRev change
  Since YAxisSetPos is READ_WRITE variable, onYAxisSetPosChange() is
void onYAxisSetPosChange()  {
  // Add your code here to act upon YAxisSetPos change
  Since YAxisHomePosmm is READ_WRITE variable, onYAxisHomePosmmChange() is
void onYAxisHomePosmmChange()  {
  // Add your code here to act upon YAxisHomePosmm change
  YAxis_HomePos = float(yAxis_HomePosmm) * (float(yAxis_PulsesPerRev) / float(YAxisLead));
  Since YAxisIndexmm is READ_WRITE variable, onYAxisIndexmmChange() is
void onYAxisIndexmmChange()  {
  // Add your code here to act upon YAxisIndexmm change
  yAxis_Index = float(yAxis_Indexmm) * (float(yAxis_PulsesPerRev) / float(YAxisLead));
  Since YAxisMoveToPosmm is READ_WRITE variable, onYAxisMoveToPosmmChange() is
void onYAxisMoveToPosmmChange()  {
  // Add your code here to act upon YAxisMoveToPosmm change
  yAxis_MoveToPos = float(yAxis_MoveToPosmm) * (float(yAxis_PulsesPerRev) / float(YAxisLead));
  Since ZAxisEnablePB is READ_WRITE variable, onZAxisEnablePBChange() is
void onZAxisEnablePBChange()  {
  // Add your code here to act upon ZAxisEnablePB change
  if (!zAxis_EnablePB){
    ZAxis.enableOutputs();
  if (zAxis_EnablePB){
  Since ZAxisIndexNegPB is READ_WRITE variable, onZAxisIndexNegPBChange() is
void onZAxisIndexNegPBChange()  {
  // Add your code here to act upon ZAxisIndexNegPB change
  if (zAxis_IndexNegPB) {
    ZAxis.move(-1 * zAxis_Index);
  Since ZAxisIndexPosPB is READ_WRITE variable, onZAxisIndexPosPBChange() is
void onZAxisIndexPosPBChange()  {
  // Add your code here to act upon ZAxisIndexPosPB change
  if (zAxis_IndexPosPB) {
    ZAxis.move(zAxis_Index);
  Since ZAxisMoveToPB is READ_WRITE variable, onZAxisMoveToPBChange() is
void onZAxisMoveToPBChange()  {
  // Add your code here to act upon ZAxisMoveToPB change
  ZAxis.moveTo(zAxis_MoveToPos);
  Since ZAxisSetPosPB is READ_WRITE variable, onZAxisSetPosPBChange() is
void onZAxisSetPosPBChange()  {
  // Add your code here to act upon ZAxisSetPosPB change
  Since ZAxisAccel is READ_WRITE variable, onZAxisAccelChange() is
void onZAxisAccelChange()  {
  // Add your code here to act upon ZAxisAccel change
  ZAxis.setAcceleration(zAxis_Accel);
  Since ZAxisIndex is READ_WRITE variable, onZAxisIndexChange() is
void onZAxisIndexChange()  {
  // Add your code here to act upon ZAxisIndex change
  zAxis_Indexmm = float(zAxis_Index) / float(zAxis_PulsesPerRev) * float(ZAxisLead);
  Since ZAxisMaxSpeed is READ_WRITE variable, onZAxisMaxSpeedChange() is
void onZAxisMaxSpeedChange()  {
  // Add your code here to act upon ZAxisMaxSpeed change
  ZAxis.setMaxSpeed(zAxis_MaxSpeed);
  Since ZAxisMoveToPos is READ_WRITE variable, onZAxisMoveToPosChange() is
void onZAxisMoveToPosChange()  {
  // Add your code here to act upon ZAxisMoveToPos change
  zAxis_MoveToPosmm = float(zAxis_MoveToPos) / float(zAxis_PulsesPerRev) * float(ZAxisLead);
  Since ZAxisPulsesPerRev is READ_WRITE variable, onZAxisPulsesPerRevChange() is
void onZAxisPulsesPerRevChange()  {
  // Add your code here to act upon ZAxisPulsesPerRev change
  Since ZAxisSetPos is READ_WRITE variable, onZAxisSetPosChange() is
void onZAxisSetPosChange()  {
  // Add your code here to act upon ZAxisSetPos change
  Since ZAxisHomePosmm is READ_WRITE variable, onZAxisHomePosmmChange() is
void onZAxisHomePosmmChange()  {
  // Add your code here to act upon ZAxisHomePosmm change
  Since ZAxisIndexmm is READ_WRITE variable, onZAxisIndexmmChange() is
void onZAxisIndexmmChange()  {
  // Add your code here to act upon ZAxisIndexmm change
  zAxis_Index = float(zAxis_Indexmm) * (float(zAxis_PulsesPerRev) / float(ZAxisLead));
  Since ZAxisMoveToPosmm is READ_WRITE variable, onZAxisMoveToPosmmChange() is
void onZAxisMoveToPosmmChange()  {
  // Add your code here to act upon ZAxisMoveToPosmm change
  zAxis_MoveToPos = float(zAxis_MoveToPosmm) * (float(zAxis_PulsesPerRev) / float(ZAxisLead));
09:13:04.649 ->   addr: 20007e98    data: 00000077
09:13:04.649 ->   addr: 20007e9c    data: 0000d5f1
09:13:04.789 ->   addr: 20007ea0    data: 20000974
09:13:04.789 ->   addr: 20007ea4    data: 20000a88
09:13:04.789 ->   addr: 20007ea8    data: 0000a500
09:13:04.789 ->   addr: 20007eac    data: ffffffff
09:13:04.909 ->   addr: 20007eb0    data: 20003064
09:13:04.909 ->   addr: 20007eb4    data: 05000000
09:13:04.909 ->   addr: 20007eb8    data: 00020000
09:13:05.047 ->   addr: 20007ebc    data: 00005819
09:13:05.047 ->   addr: 20007ec0    data: 00000000
09:13:05.047 ->   addr: 20007ec4    data: 00000000
09:13:05.229 ->   addr: 20007ec8    data: 00004040
09:13:05.229 ->   addr: 20007ecc    data: 000058e5
09:13:05.229 ->   addr: 20007ed0    data: 00000000
09:13:05.229 ->   addr: 20007ed4    data: 00015151
09:13:05.322 ->   addr: 20007ed8    data: 0001fe85
09:13:05.322 ->   addr: 20007edc    data: 40046f00
09:13:05.322 ->   addr: 20007ee0    data: 00000000
09:13:05.460 ->   addr: 20007ee4    data: 0001518f
09:13:05.460 ->   addr: 20007ee8    data: 0001fe85
09:13:05.460 ->   addr: 20007eec    data: 0000ea53
09:13:05.597 ->   addr: 20007ef0    data: 0001fe85
09:13:05.597 ->   addr: 20007ef4    data: 0001247b
09:13:05.597 ->   addr: 20007ef8    data: 00012471
09:13:05.597 ->   addr: 20007efc    data: 00002599
09:13:05.771 -> ====================================
09:13:05.771 -> Bus fault is caused by precise data access violation
09:13:05.771 -> The bus fault occurred address is fb211553
