haaad
December 5, 2018, 8:26am
#1
I am new to the forum so Hi to all,
Also new to arduino.
Not so new to microcontrolers in general.
I did some work with MSP430
I am bit rusty so I would like you to help me start so I can carry on...
I have buspirate 3.6 with 6.3 firmware (4.4 bootloader)
It works thro terminal
I did purchase adruino pro mini from amazon (UMT Media)
It seems it has some code burnt out of the box - gpio led is blinking when power on.
I have tried to connect both without joy. I am getting rc -2.
So checked the cables, changed the cables, all sorts configurations of connections (reading many forums)
Thro IDE and directly thro avrdude
I am working on win10
serial driver installed (I can talk to BP)
cables chceked for continuity etc
correct com selected for coms in ide and avrdude
what else?
I could get isp but since I already have the tool I do not want to generate more mess on my bench.
Appreciate any help please.
HD
pert
December 5, 2018, 8:30am
#2
Please do this (in the Arduino IDE):
File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
Sketch > Upload Using Programmer
After the upload fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
Paste the error messages in a reply here USING CODE TAGS (</> button on the forum toolbar).
BJHenry
December 5, 2018, 8:37am
#3
In addition to what Pert has suggested, can you tell us what USB-Serial adapter you're using for the Pro Mini?
haaad
December 5, 2018, 8:48am
#4
Cheers pert for quick reply,
I did that yesterday - do not remember the output.
I will do this again and post it here later today.
And I will do some more tests as per your converasation with mygodetjy
BJHenry - I am using buspirate.
HD
haaad
December 5, 2018, 8:58pm
#5
As promised Here is the output from the IDE:
Arduino: 1.8.7 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
Sketch uses 1152 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 13 bytes (0%) of dynamic memory, leaving 2035 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cbuspirate -PCOM2 -Uflash:w:C:\Users\hd\AppData\Local\Temp\arduino_build_60737/Fade.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM2
Using Programmer : buspirate
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : BusPirate
Description : The Bus Pirate
Attempting to initiate BusPirate binary mode...
BusPirate binmode version: 1
BusPirate SPI version: 1
avrdude: Paged flash write enabled.
AVR Extended Commands version 1
avrdude: initialization failed, rc=-2
Double check connections and try again, or use -F to override
this check.
BusPirate is back in the text mode
avrdude done. Thank you.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
haaad
December 5, 2018, 9:11pm
#6
Also did this from cmd with -v -v -v -v
But the 9000 limit and 5min waiting time for next post...
Had to trim it.
Any ideas?
avrdude -v -v -v -v -patmega328p -cbuspirate -PCOM2 -Uflash:w:Fade.ino.hex:i
avrdude: Version 6.3, compiled on Feb 17 2016 at 09:25:53
System wide configuration file is "avrdude.conf"
Using Port : COM2
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
avrdude: buspirate_send_bin():
0x0a 0x0a
avrdude: Send: . [0a] . [0a]
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00
avrdude: Send: . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00]
avrdude: Recv: B [42] B [42] I [49] O [4f] 1 [31]
avrdude: buspirate_recv_bin():
0x42 0x42 0x49 0x4f 0x31
0x01
avrdude: Send: . [01]
avrdude: Recv: S [53] P [50] I [49] 1 [31]
0x53 0x50 0x49 0x31
0x05 0x00 0x00 0x00 0x00
avrdude: Send: . [05] . [00] . [00] . [00] . [00]
avrdude: Recv: . [01]
0x01
0x49
avrdude: Send: I [49]
0x01
0x60
avrdude: Send: ` [60]
0x01
0x8a
avrdude: Send: . [8a]
0x01
0x06
avrdude: Send: . [06]
0x01
0x01
avrdude: Recv: . [01] . [00] . [01]
0x01 0x00 0x01
0x48
avrdude: Send: H [48]
0x01
0x13
avrdude: Send: . [13]
0x01
0xac 0x53 0x00 0x00
avrdude: Send: . [ac] S [53] . [00] . [00]
avrdude: Recv: . [ff] . [ff] . [ff] . [ff]
0xff 0xff 0xff 0xff
this check.
0x00
0x40
avrdude: Send: @ [40]
0x42
0x0f
avrdude: Send: . [0f]
avrdude: Recv: . [01] . [0d] . [0a] B [42] u [75] s [73] [20] P [50] i [69]
0x01 0x0d 0x0a 0x42 0x75 0x73 0x20 0x50
0x69
avrdude: Recv: r [72] a [61] t [74] e [65] [20] v [76] 3 [33] . [2e] 5 [35]
0x72 0x61 0x74 0x65 0x20 0x76 0x33 0x2e
0x35
avrdude: Recv: . [0d] . [0a] F [46] i [69] r [72] m [6d] w [77] a [61] r [72]
0x0d 0x0a 0x46 0x69 0x72 0x6d 0x77 0x61
0x72
avrdude: Recv: e [65] [20] v [76] 6 [36] . [2e] 1 [31] [20] r [72] 1 [31]
0x65 0x20 0x76 0x36 0x2e 0x31 0x20 0x72
0x31
avrdude: Recv: 6 [36] 7 [37] 6 [36] [20] [20] B [42] o [6f] o [6f] t [74]
0x36 0x37 0x36 0x20 0x20 0x42 0x6f 0x6f
0x74
avrdude: Recv: l [6c] o [6f] a [61] d [64] e [65] r [72] [20] v [76] 4 [34]
0x6c 0x6f 0x61 0x64 0x65 0x72 0x20 0x76
0x34
avrdude: Recv: . [2e] 4 [34] . [0d] . [0a] D [44] E [45] V [56] I [49] D [44]
0x2e 0x34 0x0d 0x0a 0x44 0x45 0x56 0x49
0x44
avrdude: Recv: : [3a] 0 [30] x [78] 0 [30] 4 [34] 4 [34] 7 [37] [20] R [52]
0x3a 0x30 0x78 0x30 0x34 0x34 0x37 0x20
0x52
avrdude: Recv: E [45] V [56] I [49] D [44] : [3a] 0 [30] x [78] 3 [33] 0 [30]
0x45 0x56 0x49 0x44 0x3a 0x30 0x78 0x33
0x30
westfw
December 5, 2018, 10:26pm
#7
So you’re using “Upload using Programmer” rather than just “Upload”?
Do you have the Bus Pirate connected to the Arduino’s ISP pins (which I don’t think have a dedicated connector on a Mini), or to the Arduino Serial Port (on the end of the board)?
If you’re using the serial port, you’d want to put the Bus Pirate in the UART Passthrough mode, and just use “Upload” from the Arduino IDE. (or “-carduino” when using avrdude from the cli.)
haaad
December 6, 2018, 2:00pm
#8
westfw,
I did attempt UART bridge couple of days ago without success.
So I have cycled thro some other ideas:
1.changing firmware on BP to some kinda new beta version, bricking it in the process,
2. MSP430 launchpad as isp for arduino - no joy
3. BP with STK500v2 firmware - nope
4. BP with 5.9 firmware - UART bridge - success
So thank you.
