Button Array Issues
Hey
First button array project, everything works perfect but I'm getting a Serial.print on the pressing of the button and when I release the button. I am also getting a constant Serial.print if I hold the button down constantly. What do I need to change in this code so that when a button is depressed it Serial.prints ONLY the button number once...not continiously, and not when let go.
Thanks!
#define DEBOUNCE 10  // button debouncer, how many ms to debounce, 5+ ms is usually plenty
// here is where we define the buttons that we'll use. button "1" is the first, button "6" is the 6th, etc
byte buttons[] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46,47, 48, 49, 50, 51, 52, 53}; // the analog 0-5 pins are also known as 14-19
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
// we will track if a button is just pressed, just released, or 'currently pressed'
byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
  byte i;
  // set up serial port
  Serial.print("Button checker with ");
  Serial.print(NUMBUTTONS, DEC);
  Serial.println(" buttons");
  // pin13 LED
  pinMode(13, OUTPUT);
  // Make input & enable pull-up resistors on switch pins
  for (i=0; i< NUMBUTTONS; i++) {
    pinMode(buttons[i], INPUT);
    digitalWrite(buttons[i], HIGH);
void check_switches()
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  static long lasttime;
  byte index;
  if (millis() < lasttime) {
     // we wrapped around, lets just try again
     lasttime = millis();
  if ((lasttime + DEBOUNCE) > millis()) {
    // not enough time has passed to debounce
    return;
  // ok we have waited DEBOUNCE milliseconds, lets reset the timer
  for (index = 0; index < NUMBUTTONS; index++) {
    justpressed[index] = 0;       // when we start, we clear out the "just" indicators
    justreleased[index] = 0;
    currentstate[index] = digitalRead(buttons[index]);   // read the button
    Serial.print(index, DEC);
    Serial.print(": cstate=");
    Serial.print(currentstate[index], DEC);
    Serial.print(", pstate=");
    Serial.print(previousstate[index], DEC);
    Serial.print(", press=");
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
          // just pressed
          justpressed[index] = 1;
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
          // just released
          justreleased[index] = 1;
      pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed
    //Serial.println(pressed[index], DEC);
    previousstate[index] = currentstate[index];   // keep a running tally of the buttons
  check_switches();      // when we check the switches we'll get the current state
  for (byte i = 0; i < NUMBUTTONS; i++) {
    if (pressed[i]) {
      Serial.print(i,DEC);
      // is the button pressed down at this moment
You should move your print statements into check_switches () where you detect a change in button state. Not everytime round the loop()...
Also I note you don't know the neat way of detecting an elapsed time without having to worry about time values wrapping round. Instead of going   if ((lasttime + DEBOUNCE) > millis()) {
you need to do
  if (millis() - lasttime > DEBOUNCE) {
Which won't go wrong on the wrap-around.
appreciate the help!
