Button being ignored
The if (digitalRead(Limit_1) == LOW) is being ignored.
I am not seeing any Serial.print() ouput.
My stepper motor is running.
digitalWrite(ENA, LOW); "should" stop the motor.
// motor runs
// Include the AccelStepper Library
#include <AccelStepper.h>
const int dirPin = 6;
const int stepPin = 7;
const int ENA = 4;
//int Limit_1 = 11;
int Limit_1 = A5;
//int ENA = 4;
AccelStepper myStepper(AccelStepper::DRIVER, stepPin, dirPin);           // works for a4988 (Bipolar, constant current, step/direction driver)
   myStepper.setMaxSpeed(5000);   // this limits the value of setSpeed(). Raise it if you like. 15000 does not work
   myStepper.setSpeed(1000);   // [12495 works with METRO 12500 does not work]
    pinMode(Limit_1,INPUT_PULLUP);
    //pinMode(ENA, OUTPUT);    // sets the digital pin 4 as output
    //digitalWrite(ENA, HIGH);
    //digitalWrite(Limit_1, HIGH);
  //if (digitalRead(Limit_1) == HIGH)
    //ENA = LOW;
    //ENA = HIGH;
    Serial.print(digitalRead(Limit_1));
    Serial.print("++++");
    //Serial.println(ENA);
    Serial.println(digitalRead(ENA));
   myStepper.runSpeed();   // This will run the motor forever.
Ralph
Maybe it is wired wrong in the schematic you didn't post.
You tried both of the above and nothing is printed for either one?
Yes I tried both.
The switch is just wired to ground and A5.
Do you really want a schematic?
Ralph
Given that the other pins used are digital pins, but you've specified that your switch is wired to an analogue pin, I don't think it's unreasonable.
I have tried using the digital pins with the same results.
So I switched to the Analog just to see if it made a difference.
No difference.
Ralph
Hello
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
The code is posted in my first post.
But here ya go again.
// motor runs
const int ENA = 4;
//int Limit_1 = 11;
int Limit_1 = A5;
//int ENA = 4;
  if (digitalRead(Limit_1) == LOW)    //being ignored button press makes no difference. No Serial.print() output.
    //ENA = LOW;
    //ENA = HIGH;
    Serial.print(digitalRead(Limit_1));    //Nothing
I would double check the switch connection to GND and the cables. And the switch itself...
Everything has been triple checked and used on other sketches so I know the switch and wiring works!
Ralph
One more time :wink: .
Show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
const byte Limit_1 = A5;
    pinMode(Limit_1, INPUT_PULLUP);
    Serial.println(digitalRead(Limit_1) == HIGH ? "HIGH" : "LOW");
Disconnect everything from the Arduino except the usb cable and the button. Do you see anything on serial monitor like that?
I see:
HIGH
HIGH
Ralph
I'd be very worried if I saw '?'
Looks like you've broken something, badly.
OK, you don’t see where we are going with this?
Place a jumper between A4 and ground and see what happens…
And if your switch won’t do that, you broke your need a new switch. :expressionless:
a7
Which motor driver? Maybe LOW IS enable.
No. The jumper goes from A5 to ground for Ralph to see
LOW
LOW
Going A5 to ground is the same as the switch.
The switch is working. I can use it with other sketches.
I am going to set up a new UNO with just a switch and a LED to demonstrate the problem.
Any one would be able to replicate easily what I am seeing.
I will even attempt to do a Fritzing schematic.
Ralph
LOL, I actually ‘fixed’ that from A0 after looking back at the code. THX.
a7
