Wanted to share the code that i had written to handle single click, double click and long click from ISR for any button.
Code can be found at GitHub - m-santh/Arduino-Multiclick: Arduino code for multiple click
class MultiButton {
private:
static const int DEBOUNCE_DELAY = 50; // ms
static const int DOUBLECLICK_DELAY = 250; // ms
static const int LONGCLICK_DELAY = 350; // ms
static const int STATE_IDLE = 0;
static const int STATE_SINGLE_CLICK = 1;
static const int STATE_DOUBLE_CLICK = 2;
static const int STATE_LONG_CLICK = 3;
unsigned int _lastTransition;
int _state;
bool _singleClick;
bool _longPress;
bool _doubleClick;
int _pin;
public:
- MultiButton constructor.
MultiButton(int pin) : _lastTransition(millis()), _state(LOW), _singleClick(false), _longPress(false), _doubleClick(false), _pin(pin) {
- Decode hardware button state into clean clicks (single, double, long).
- The state of isClick() etc is valid until the next call to update().
- Periodically call update() with the current (raw, non-debounced)
- state of a (hardware) button.
- Suggestion is to put it in e.g. loop(), but make sure to call it at
- least every ~20ms.
@param pressed {bool} Whether raw button is currently pressed
int checkPress() {
bool previousPressed = (_state == HIGH);
bool pressed = (PCF_01.digitalRead(_pin) == HIGH);
int currentClick = STATE_IDLE;
unsigned int now = millis();
int diff = now - _lastTransition;
// Pressed state change
if(pressed && !previousPressed) {
_lastTransition = now;
_state = HIGH;
_singleClick = true;
currentClick = STATE_SINGLE_CLICK;
if(_doubleClick && diff <= DOUBLECLICK_DELAY) {
_longPress = false;
else {
_longPress = true;
_doubleClick = false;
// Release state change
if(!pressed && previousPressed) {
// Check if long press
if(_doubleClick) {
currentClick = STATE_DOUBLE_CLICK;
else if(_longPress && diff > LONGCLICK_DELAY) {
currentClick = STATE_LONG_CLICK;
else {
_doubleClick = true;
_state = LOW;
_singleClick = false;
_longPress = false;
return currentClick;
