Button control stepper motor forward and backward
Used two buttons to control the stepper motor forward and backward by the sketch attached, it was OK. I tried to stop the motor by changed the myStepper.setSpeed(motorSpeed); into myStepper.setSpeed(0); and used BTStop button, the motor can't restart again even pressed the Forward button after BTStop pressed. why? how to use button control the running stepper motor?
Thanks
//20200528 test GOOD!
const int BTSMForward  = A2;
const int BTSMBackward = A3;
int BTSMForwardState = 0;
int BTSMBackwardState = 0;
const int BTStop = A4;
int BTStopState = 0;
#include <Stepper.h>
const int stepsPerRevolution = 200;  /
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
int stepCount = 0;  // number of steps the motor has taken
  pinMode(BTSMForward, INPUT_PULLUP);
  pinMode(BTStop, INPUT_PULLUP);
} // close setup
  button();
void button() {
  BTStopState = digitalRead(BTStop);
  if (!BTStopState) {
    Stop();
  BTSMForwardState = digitalRead(BTSMForward);
  if (BTSMForwardState) {
    ForwardSM();
  BTSMBackwardState = digitalRead(BTSMBackward);
  if (BTSMBackwardState) {
    BackwardSM();
// close void loop
void ForwardSM() {
  // read the sensor value:
  int sensorReading = analogRead(A0);
  // map it to a range from 0 to 100:
  int motorSpeed = map(sensorReading, 0, 1023, 0, 100);
  // set the motor speed:
  if (motorSpeed > 0) {
    // step 1/100 of a revolution:
    myStepper.step(stepsPerRevolution / 100);
void BackwardSM() {
    ///  myStepper.setSpeed(motorSpeed);
    myStepper.step(-stepsPerRevolution / 100);
void Stop() {
  Serial.print("stop");
  //  Serial.print();
    myStepper.step(-stepsPerRevolution / 100); // this can't happen with speed set to 0,
                                                // your code probably hangs here
This is not the right way to go about it
void button() {
  if (!BTStopState) {
    Stop();
    ForwardSM();
    BackwardSM();
You have three separate variables but logically the motor can only do one thing so you should have a single variable let's call it motorState and depending on which button is pressed it should have the values 'S' for stop, 'F' for forward and 'B' for backward.
And then the code in the action functions can just check that variable to decide if they should work - for example
void ForwardSM() {
    if (motorState != 'F') {
         return)
    // the rest of the code
and the functions ForwardSM() etc should be called from loop() like this
  button();
  ForwardSM();
  // etc
...R
  • don't you need a pinMode for BTSMBackward?
  • your Forward(), Backward() and Stop() are very similar. why not have just one function that uses global variables for speed or direction and recognize that speed == 0 implies stop
  • in button, why not set parameters for speed: 0, + or -, instead of calling unique functions
  • do you need to capture a button press so the motor function is only called once.
Robin2:
void button() {
if (!BTStopState) {
Stop();
ForwardSM();
BackwardSM();
void ForwardSM() {
        return)
  button();
  ForwardSM();
  // etc
...R
Thanks, you are right, I was planning to use three buttons like you mentioned, F for forward, B-backward, S-stop, in the third Subroutine I coded: myStepper.setSpeed(0) works , the stepper motor stop when I pressed the S button.
The problem is the motor can never restart again, even pressed F or B.
Best
JCA34F:
Thanks
myStepper.step(-stepsPerRevolution / 100); this make the motor reverse only;
myStepper.setSpeed(0); this make the motor stop.
Best
gcjr:
Thanks, you are right, I need a pinMode for BTSMBackward? but the code work well on Arduino UNO, and the F/B buttons work well. problem came as long as I added S button.
Yes, I'll learn to config the button and try to use just one.
Best
