# button cycled NeoPixel on Digispark ATtiny85
**URL:** <https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835>\
**Category:** General Guidance\
**Created:** [February 3, 2019, 11:25pm UTC](https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835 "2019-02-03T23:25:25Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![surveyranger](https://avatars.discourse-cdn.com/v4/letter/s/46a35a/32.png) [@surveyranger](https://forum.arduino.cc/u/surveyranger)\
**Post date:** [February 3, 2019, 11:25pm UTC](https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835/1 "2019-02-03T23:25:25Z")
</div>
I believe I may be suffering paralysis by analysis. I modified the Adafruit\_Neopixel example for 'buttoncycler' to use with a digispark ATtiny 85. I plan to eventually make it battery powered hence the need for low power consumption. I broke it down into phases to help focus my efforts:
Phase 1 = Get buttoncycler example/circuit to work and customize showTypes [**_complete_**]
Phase 2 = Have current showType stop (even in the middle of running) when button pressed and advance to next showType (case)
Phase 3 = Have current showType repeat until button pressed or uC goes to sleep from 5-min idle timer
Phase 4 = Add a sleep mode to wake on external interrupt (button on P2)
Phase 5 = Optimize to reduce uAh and mAh
I've tried various things after reading different posts on the forums and websites. I have the [Arduino Reference](https://www.arduino.cc/reference/en/), Robin2's post [Demonstration code...](http://forum.arduino.cc/index.php?topic=223286.0), UKHelibob's post on [Using millis()...](http://forum.arduino.cc/index.php?topic=503368.msg3433063#msg3433063), and Nick Gammon's [Interrupts](http://gammon.com.au/interrupts) opened in their own tabs trying to piece something together.
Where I'm stuck at now is getting the button press recognized when a showType is running. For instance, in case (1) the colorWipe runs through the different cycles then stops at the end of the function even if I tap the button repeatedly. I tried using a $1 WAVGAT Pro Mini clone, but it did not like the Neopixel library so I switched to the Sparky85.
Code to follow in next post due to size
 ![](https://europe1.discourse-cdn.com/arduino/original/4X/6/8/c/68c32272976351ec706113a377c07cbdf3968bba.jpeg)
**Post date:** [February 3, 2019, 11:32pm UTC](https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835/2 "2019-02-03T23:32:02Z")
</div>
```cpp
/* Cycle NeoPixels with button using Digispark ATtiny85 (microUSB version)
 *  Button on P2 (PCINT0) cycles through different modes (cases). Mode stops and switches to the
 *  next mode when button is pressed.  Current mode plays until button is pressed or goes into
 *  low power mode after 5 minutes.  uC wakes on button press on P2 (PCINT0) and continues program.
 *  User can turn off circuit with switched attached to VIN.  User needs to press the
 *  button once to start the first animation!
 *  Momentary push button is wired to connect P2 to ground. P2 kept high by internal pullup.
 *  NeoPixel data in connected in series with a 330 ohm resistor to P0.
 *  Neopixel 5V and GND pins connected to Digispark ATtiny85 power rail 5V and GND pins, respectively.
 *  Program will eventually include SLEEP_MODE_PWR_DOWN & wdt_disable so it only awakens with PCINT0
 *  ISSUE LOG:
 *  1. Button press does not stop showType in middle of function
 *  2. showType runs once and stops rather than keeps running until button pressed or 5-min sleep timer
 *  3. Minimize power draw when awake
 *  4. Remove delay() in showType functions
 *  5. case(0) is skipped when first initialized and setup() finishes. Pressing button changes LEDs from green
 *     to case(1) colorWipe
// #include <avr/sleep.h>         // library for sleep modes
// #include <avr/power.h>         // library for power managements
// #include <avr/wdt.h>           // Needed to disable/enable WDT??
// #include <avr/interrupt.h>     // library for interrupts
#ifdef __AVR__
#endif
#define BUTTON_PIN   2   // P2 (PCINT0) pin for button
#define PIXEL_PIN    0    // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 9
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
bool oldState = HIGH;
bool newState;
byte showType = 0;        //changed from (16bit)int to (8bit)byte to reduce size
unsigned long startMillis;
unsigned long currentMillis;
void debounce() {
const byte debouncePeriod = 20;  // number of MS for button debounce [changed from (32bit)const unsigned long to (8 bit)const byte]
boolean debouncing = false;
  unsigned long debounceStartMillis = currentMillis;  //save the time that the state change occured
  debouncing = true;  //flag that debouncing in progress
    if (currentMillis - debounceStartMillis >= debouncePeriod)  //if the debounce period has elapsed
      if (debouncing == true)    //debouncing taking place
        if (digitalRead(BUTTON_PIN) == LOW)     //if the button is currently pressed
          debouncing = false;    //debouncing is finished
/*  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
  #if defined ( __AVR_ATtiny85__ )
    if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
  #endif
  // End of trinket special code
  pinMode(PIXEL_PIN, OUTPUT);
  digitalWrite(BUTTON_PIN, HIGH);  // activate pull-up resistor to set pin HIGH
  pinMode(1, INPUT);  // Turn unused pins to INPUTs to conserve battery
  pinMode(3, INPUT);  // when in sleep mode. Should be INPUT by default??
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  strip.begin();
  strip.setBrightness(50);  // dim output to conserve battery
  strip.show(); // Initialize all pixels to 'off'
  // Neopixel color test
  colorWipe(strip.Color(255, 0, 0), 50); // Red
  colorWipe(strip.Color(0, 0, 255), 50); // Blue
  colorWipe(strip.Color(0, 255, 0), 50); // Green
  startMillis = millis();  //initial start time
// pin change interrupt
//  PCMSK  |= bit (PCINT0);  // want P2 on Digispark
//  GIFR   |= bit (PCIF);    // clear any outstanding interrupts
//  GIMSK  |= bit (PCIE);    // enable pin change interrupts
  //get the current "time" (actually the number of milliseconds since the program started)
  currentMillis = millis();
  // Get current button state.
  newState = digitalRead(BUTTON_PIN);
  // Check if state changed from high to low (button press).
  if (newState != oldState)  // was (newState == LOW && oldState == HIGH)
    // Run button debounce function
    debounce();
    // Check if button is still low after debounce.
    if (newState == LOW)   // Verifies it really is a button press
      showType++;
      if (showType > 6)
        showType=0;
      startShow(showType);
  // Set the last button state to the old state.
  oldState = newState;
void startShow(int i) {
  switch(i) {
    case 0: colorWipe(strip.Color(0, 0, 0), 50);         // Black/off
    case 1: colorWipe(strip.Color(153, 0, 255), 200);    // Purple: Signifies pain, suffering, grief, and mourning
            colorWipe(strip.Color(255, 0, 153), 200);    // Pink: Celebration
            colorWipe(strip.Color(127, 127, 127), 200);  // White: Purity and hope
            colorWipe(strip.Color(200, 51, 0), 200);     // Orange: Sun
            colorWipe(strip.Color(255, 0, 0), 200);      // Red: The blood of life
            colorWipe(strip.Color(255, 200, 0), 200);    // Yellow: Cempazuchitl are marigolds that symbolize death.
    case 2: theaterChase(strip.Color(153, 0, 255), 200);    // Purple
            theaterChase(strip.Color(255, 0, 153), 200);    // Pink
            theaterChase(strip.Color(127, 127, 127), 200);  // White
            theaterChase(strip.Color(200, 51, 0), 200);     // Orange
            theaterChase(strip.Color(255, 0, 0), 200);      // Red
            theaterChase(strip.Color(255, 200, 0), 200);    // Yellow
    case 3: rainbow(50);
    case 4: rainbowCycle(20);
    case 5: theaterChaseRainbow(50);
    case 6: colorWipe(strip.Color(0, 0, 0), 50);    // Black/off
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t showSpeed) {
  for(uint16_t i=0; i<strip.numPixels(); i++)
    strip.setPixelColor(i, c);
    strip.show();
   if (digitalRead(BUTTON_PIN) == LOW)   // Check if button pressed
      break;                              // If button pressed, move to next showType
    delay(showSpeed);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t showSpeed) {
  for (int j=0; j<10; j++)  //do 10 cycles of chasing
    for (int q=0; q < 3; q++)
      for (int i=0; i < strip.numPixels(); i=i+3)
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(showSpeed);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
void rainbow(uint8_t showSpeed) {
  uint16_t i, j;
  for(j=0; j<256; j++)
    for(i=0; i<strip.numPixels(); i++)
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(showSpeed);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t showSpeed) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++)
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(showSpeed);
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t showSpeed) {
  for (int j=0; j < 256; j++)     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(showSpeed);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85)
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170)
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
**Post date:** [February 5, 2019, 4:15am UTC](https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835/3 "2019-02-05T04:15:42Z")
</div>
Not sure if I ask really good questions or really bad questions since I never received any replies. Pretty sure it's the latter.
Phase 1 = Get buttoncycler example/circuit to work and customize showTypes ( **_complete_** )
Phase 3a = Have current showType repeat until button pressed ( **_complete_** )
Phase 3b = Have current showType repeat until uC goes to sleep from 5-min idle timer
Made some changes to the code that got me some progress after 2-3 days of reading/editing. Any suggestions on how to stop a "for loop" or "for loops" nested together when I press a button? I've tried while, do/while, goto, if, break, return, continue.... but nothing seems to work as intended (although I'm sure it's working as written). I attached screencaps of a function (showType) that I wanted to interrupt. The examples/references in the IDE and on the website do not normally involve "for loops." I'm hesitant to try an interrupt because I want to use the button pin as an external interrupt when Sparky is asleep. Can I have 1 pin do 2 interrupts??
 ![](https://europe1.discourse-cdn.com/arduino/original/4X/a/d/a/ada09e6aef7b13988f8f584487c62295009a343e.jpeg)
```cpp
 * ISSUE LOG:
 * 2. showType runs until button pressed nut NOT 5-min sleep timer
#ifdef __AVR__
#endif
#define BUTTON_PIN 2 // Digital IO pin connected to the button.
bool buttonPressed = false;
bool newState = HIGH;
int showType = 0;
const int debouncePeriod = 20;
unsigned long debounceStartMillis;
void testPixels()
// Check state of button
void checkButton()
      if (digitalRead(BUTTON_PIN) == LOW) // if button still pressed
        newState = LOW;
        oldState += newState; // Update oldState to last button state (newState)
        buttonPressed = true; // trying to set flag that button is pressed
    newState = HIGH;
  #endif
  strip.begin();
  testPixels();
  // Call to checkButton function
  checkButton();
  if (buttonPressed == true)
    showType++;
    if (showType > 8)
    showType = 0;
// oldState = newState;
  switch(i) {
    case 0: checkButton();
    case 1: checkButton();
    case 2: checkButton();
    case 3: checkButton();
            rainbow(10);
    case 4: checkButton();
            rainbowCycle(20);
    case 5: checkButton();
    case 6: checkButton();
            rainbow(50);
    case 7: checkButton();
            rainbowCycle(50);
    case 8: checkButton();
            theaterChaseRainbow(100);
    strip.show();
    delay(showSpeed);
      strip.show();
      delay(showSpeed);
  uint16_t i, j;
    strip.show();
    delay(showSpeed);
  uint16_t i, j;
    strip.show();
    delay(showSpeed);
      strip.show();
      delay(showSpeed);
  if(WheelPos < 85)
  if(WheelPos < 170)
    WheelPos -= 85;
  WheelPos -= 170;
**Author:** ![Grumpy\_Mike](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/grumpy_mike/32/213521_2.png) [@Grumpy\_Mike](https://forum.arduino.cc/u/Grumpy_Mike)\
**Post date:** [February 5, 2019, 6:03am UTC](https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835/4 "2019-02-05T06:03:14Z")
</div>
Yes you don't write them in the first place, unless you want to do a lot of things in one step and there is no delay in it. Nesting them is bad.
You need to write your code as a state machine, what you have at the moment is not one because it contains for loops.
This examples shows you how to do this for all the standard Adafruit patterns.
```arduino
// StrandTest from AdaFruit implemented as a state machine
// pattern change by push button
// By Mike Cook Jan 2016
// Fade function added Sept 2017
#define PINforControl   4 // pin connected to the small NeoPixels strip
#define NUMPIXELS1      64 // number of LEDs on strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS1, PINforControl, NEO_GRB + NEO_KHZ800);
unsigned long patternInterval = 20 ; // time between steps in the pattern
unsigned long lastUpdate = 0 ; // for millis() when last update occoured
unsigned long intervals [] = { 20, 20, 50, 100, 30 } ; // speed for each pattern - add here when adding more cases
int fadeStep = 0; // stste variable for fade function
int numberOfCases = 4; // how many case statements or patterns you have
const byte button = 3; // pin to connect button switch to between pin and ground
  strip.begin(); // This initializes the NeoPixel library.
  wipe(); // wipes the LED buffers
  pinMode(button, INPUT_PULLUP); // change pattern button
  static int pattern = 4, lastReading; // start with the fade function
  int reading = digitalRead(button);
  if(lastReading == HIGH && reading == LOW){
    pattern++ ; // change pattern number
    fadeStep = 0; // reset the fade state variable
    if(pattern > numberOfCases) pattern = 0; // wrap round if too big
    patternInterval = intervals[pattern]; // set speed for this pattern
    wipe(); // clear out the buffer
    delay(50); // debounce delay
  lastReading = reading; // save for next time
if(millis() - lastUpdate > patternInterval) updatePattern(pattern);
void  updatePattern(int pat){ // call the pattern currently being created
  switch(pat) {
    case 0:
        rainbow();
    case 1:
        rainbowCycle();
    case 2:
        theaterChaseRainbow();
    case 3:
         colorWipe(strip.Color(255, 0, 0)); // red
    case 4:
         fade(0,255, 0,64, 0,0, 400); // fade from black to oraange and back
void fade(int redStartValue, int redEndValue, int greenStartValue, int greenEndValue, int blueStartValue, int blueEndValue, int totalSteps) {
static float redIncrement, greenIncrement, blueIncrement;
static float red, green, blue;
static boolean fadeUp = false;
if (fadeStep == 0){ // first step is to initialise the initial colour and increments
  red = redStartValue;
  green = greenStartValue;
  blue = blueStartValue;
  fadeUp = false;
  redIncrement = (float)(redEndValue - redStartValue) / (float)totalSteps;
  greenIncrement = (float)(greenEndValue - greenStartValue) / (float)totalSteps;
  blueIncrement = (float)(blueEndValue - blueStartValue) / (float)totalSteps;
  fadeStep = 1; // next time the function is called start the fade
else { // all other steps make a new colour and display it
  // make new colour
  red += redIncrement;
  green +=  greenIncrement;
  blue += blueIncrement;
  // set up the pixel buffer
  for (int i = 0; i < strip.numPixels(); i++) {
  strip.setPixelColor(i, strip.Color((int)red,(int)green,(int)blue));
 // now display it
  strip.show();
fadeStep += 1; // go on to next step
if(fadeStep >= totalSteps) { // finished fade
  if(fadeUp){ // finished fade up and back
     fadeStep = 0;
     return; // so next call recalabrates the increments
  // now fade back
  fadeUp = true;
  redIncrement = -redIncrement;
  greenIncrement = -greenIncrement;
  blueIncrement = -blueIncrement;
  fadeStep = 1; // don't calculate the increments again but start at first change
void rainbow() { // modified from Adafruit example to make it a state machine
  static uint16_t j=0;
    for(int i=0; i<strip.numPixels(); i++) {
    strip.show();
     j++;
  if(j >= 256) j=0;
  lastUpdate = millis(); // time for next change to the display
void rainbowCycle() { // modified from Adafruit example to make it a state machine
    for(int i=0; i< strip.numPixels(); i++) {
    strip.show();
  j++;
  if(j >= 256*5) j=0;
void theaterChaseRainbow() { // modified from Adafruit example to make it a state machine
  static int j=0, q = 0;
  static boolean on = true;
     if(on){
            for (int i=0; i < strip.numPixels(); i=i+3) {
      else {
     on = !on; // toggel pixelse on or off for next time
      strip.show(); // display
      q++; // update the q variable
      if(q >=3 ){ // if it overflows reset it and update the J variable
        q=0;
        j++;
        if(j >= 256) j = 0;
void colorWipe(uint32_t c) { // modified from Adafruit example to make it a state machine
  static int i =0;
    strip.show();
  i++;
  if(i >= strip.numPixels()){
    i = 0;
    wipe(); // blank out strip
void wipe(){ // clear all LEDs
     for(int i=0;i<strip.numPixels();i++){
       strip.setPixelColor(i, strip.Color(0,0,0));
  if(WheelPos < 85) {
  if(WheelPos < 170) {
    WheelPos -= 85;
  WheelPos -= 170;
Very bad, difficult to read - used a Fritzing diagram (always bad), long and rambling difficult to understand - showed code as a screen dump meaning impossible for us to recreate
**Post date:** [February 5, 2019, 1:37pm UTC](https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835/5 "2019-02-05T13:37:14Z")
</div>
> Grumpy\_Mike:
Very good distinction on for loops. I'll remember that moving forward.
> Grumpy\_Mike:
Thank you for the example. I'll look it over to see how I can get rid of those for loops and complete Phase 2.
> Grumpy\_Mike:
Thanks for the feedback.
**Post date:** [February 10, 2019, 1:16am UTC](https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835/6 "2019-02-10T01:16:57Z")
</div>
I got the Pixels to cycle as desired, but ran into a snag when I tried to add a sleep mode to wake on an external interrupt only on pin 2(PCINT0).
When I added the extra code, ol' Sparky85 does nothing...visibly. My laptop starts cycling through recognizing Sparky85 & disconnecting. Tried using a USB power bank, but same results. Button does not "wake up" or cycle through the patterns. The power LED is on though (until I remove it). This is my first attempt at sleep functions and ISRs.
Since it doesn't even start blinking the pixels, then I think it's in the setup(). Anybody see where the hangup is?
Code added to sleep & wake (hypothetically)
```cpp
// Function to put Digispark to sleep
void goToSleep ()
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);  // sets the mode for power consumption during sleep
  pinMode(PIXEL_PIN, INPUT);            // Change pin to input
  ADCSRA = 0;                          // Turn off ADC if not already done in setup()
  power_all_disable();                  // power off ADC, Timer 0 and 1, serial interface
  wdt_disable();                        // Disable Watchdog Timer so only button wakes up MCU
  sleep_enable();                      // Enables the sleep bit so that the processor can actually be put to sleep with sleep_mode ()
  sleep_bod_disable();                  // Disable brown out detection to reduce power consumption in sleep mode. Auto-enables on wake
  noInterrupts();                      // Turn other interrupts OFF while attaching interrupt
  attachInterrupt(0, awakeNow, LOW);    // 0 = PCINT0 = P2 on button press, fires the ISR to wake up processor
  interrupts();                        // Turn interrupts ON
  sleep_mode();                        // Should now be sleeping like a baby
  sleep_disable();                      // Program returns to this point when the ISR fires
  detachInterrupt(0);                  // Stop MCU from registering BUTTON_PIN press to LOW
  wdt_enable(WDTO_8S);                  // Enable Watchdog Timer to 8S
  power_all_enable();                  // power everything back on
  ADCSRA = 0;                          // Turn off ADC because I don't need it
  pinMode(PIXEL_PIN, OUTPUT);          // Change pin to output
// Interrupt Service Routine (ISR) to wake up the Digispark
void awakeNow ()
  // ISR blank or add detachInterrupt(0);?
void setup
  ADCSRA = 0;              // Turn off ADC because I don't need it??
void loop
  static byte idleTime = 1;  // Sets idle time before sleep mode
  if (millis() - idleMillis >= (1000UL*60*idleTime))  // 1000(unsigned long)ms * 60(sec/min) * # minutes
    goToSleep();      // Will uncomment once sleep/wake functions correct
if (newState == LOW && oldState == HIGH)
    showType++;                // Move to next showType
    idleMillis = millis();    // Reset idle timer
Most of the code (without all the functions to blink the pixels)
```cpp
#include <avr/wdt.h>          // disable/enable WDT
#include <avr/interrupt.h>    // library for interrupts NEEDED???
#ifdef __AVR__
#endif
unsigned long idleMillis;  // Measure idle time between button presses
unsigned long lastUpdate = 0;  // for millis() when last update occurred
unsigned long showSpeed [] = { 30, 30, 30, 10, 10, 30, 60, 60, 60 } ; // speed for each pattern - add here when adding more cases
const byte BUTTON_PIN = 2;  // Pin 2 / PCINT0 / externalInturrupt
void goToSleep ()
void awakeNow ()
// Set unused pins to INPUT and LOW to save power
void inputsLow ()
  digitalWrite(1, INPUT);
  digitalWrite(3, INPUT);
  digitalWrite(4, INPUT);
  digitalWrite(1, LOW);
  digitalWrite(3, LOW);
  digitalWrite(4, LOW);
  pinMode(BUTTON_PIN, INPUT);
  inputsLow();                              // Set other pins to LOW
  strip.begin();
  idleMillis = millis();    // Start idle time
  // Start with case 0
  static byte showType = 0;
  static bool oldState;
  bool newState = digitalRead(BUTTON_PIN);
    if (showType > 8)          // If showType exceeds number of shows
    showType = 0;              // Reset showType to case 0
    patternInterval = showSpeed[showType];  // Set speed for this pattern
    delay(20);                // Debounce delay
  oldState = newState;        // Update state
  if (millis() - lastUpdate > patternInterval)
Function with switch/case with different patterns
Phase 1 = Get buttoncycler example/circuit to work and customize showTypes **(complete)**
Phase 2 = Have current showType stop (even in the middle of running) when button pressed and advance to next showType (case) **(complete)**
Phase 3a = Have current showType repeat until button pressed **(complete)**
Phase 3b = Have current showType repeat until uC goes to sleep from 1/5/10-min idle timer\_\__(in progress)_\_\_
Phase 4 = Add a sleep mode to wake on external interrupt (button on P2) **_(in progress)_**
Phase 5 = Optimize to reduce mAh to uAh
**Post date:** [February 15, 2019, 4:40am UTC](https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835/7 "2019-02-15T04:40:28Z")
</div>
Made a few sacrifices in the coding and wiring, but I'm finished with this project. Final code below if anyone is interested.
 ![](https://europe1.discourse-cdn.com/arduino/original/4X/0/3/1/0319fd27be70ff668b8fd55238e785384c413537.jpeg)
.ino File attached because code exceeded 7000 characters.
[DOTD\_DDLM\_Pendant.ino](https://forum.arduino.cc/uploads/short-url/nkpLF9eE0ndx8qMmjaujgSTCjXh.ino) (12.9 KB)
**Post date:** [May 5, 2021, 6:48pm UTC](https://forum.arduino.cc/t/button-cycled-neopixel-on-digispark-attiny85/571835/8 "2021-05-05T18:48:51Z")
</div>
Closed on May 5, 2021, 6:48pm UTC
