Hi, i need help.(sorry for bad english) I need to make a code for a university problem.
When X1 button is pressed it goes to the next state, when X2 is pressed it goes back, its supose to simulate cars entering and exiting a parquing lot. The problem is that i cant have any delays on the program,but if dont have the delay it jumps states (from 0 to 10 in an instante), my professor said to use a debounce on the buttons but i dont know how. And it needs to be an FSM.
The code might not be the best but i am trying my best.
short int L0_pin = 2;
short int L1_pin = 3;
short int L2_pin = 4;
short int LA_pin = 5;
short int LB_pin = 6;
short int LC_pin = 7;
short int LD_pin = 8;
short int LE_pin = 9;
short int LF_pin = 10;
short int LG_pin = 11;
short int LH_pin = 1;
short X1_pin = 13;
short X2_pin = 12;
short int L2_out;
short int L1_out;
short int L0_out;
short int LA_out;
short int LB_out;
short int LC_out;
short int LD_out;
short int LE_out;
short int LF_out;
short int LG_out;
short int LH_out;
pinMode(L0_pin, OUTPUT);
pinMode(L1_pin, OUTPUT);
pinMode(L2_pin, OUTPUT);
pinMode(LA_pin, OUTPUT);
pinMode(LB_pin, OUTPUT);
pinMode(LC_pin, OUTPUT);
pinMode(LD_pin, OUTPUT);
pinMode(LE_pin, OUTPUT);
pinMode(LF_pin, OUTPUT);
pinMode(LG_pin, OUTPUT);
pinMode(LH_pin, OUTPUT);
pinMode(X1_pin, INPUT);
pinMode(X2_pin, INPUT);
static short int trigger_in;
short int trigger_out;
static short int L2_in;
static short int L1_in;
static short int L0_in;
static short int LA_in;
static short int LB_in;
static short int LC_in;
static short int LD_in;
static short int LE_in;
static short int LF_in;
static short int LG_in;
static short int LH_in;
short int X1;
short int X2;
X1 = (short)digitalRead(X1_pin);
X2 = (short)digitalRead(X2_pin);
counter_fsm(X1,X2);
Serial.print(L2_in);
Serial.print(L1_in);
Serial.println(L0_in);
digitalWrite(L0_pin,L0_in);
digitalWrite(L1_pin,L1_in);
digitalWrite(L2_pin,L2_in);
digitalWrite(LA_pin,LA_in);
digitalWrite(LB_pin,LB_in);
digitalWrite(LC_pin,LC_in);
digitalWrite(LD_pin,LD_in);
digitalWrite(LE_pin,LE_in);
digitalWrite(LF_pin,LF_in);
digitalWrite(LG_pin,LG_in);
digitalWrite(LH_pin,LH_in);
L0_in = L0_out;L1_in = L1_out;L2_in = L2_out;
LA_in = LA_out;LB_in = LB_out;LC_in = LC_out;
LD_in = LD_out;LE_in = LE_out;LF_in = LF_out;
LG_in = LG_out;LH_in = LH_out;
void counter_fsm(short X1,short X2){
static short int state;
switch (state) {
case 0:
delay(200);
if ( X1 == 1) {state = 1;}
if ( X2 == 1) {state = 0;}
L2_out = 0;L1_out = 0;L0_out = 1;
LA_out = 0;LB_out = 0;LC_out = 0; LD_out = 0;LE_out = 0;
LF_out = 0;LG_out = 1;LH_out = 1;
case 1:
delay(200);
if ( X1 == 1) {state = 2;}
LA_out = 1;LB_out = 0;LC_out = 0; LD_out = 1;LE_out = 1;
LF_out = 1;LG_out = 1;LH_out = 1;
case 2:
delay(200);
if ( X1 == 1) {state = 3;}
if ( X2 == 1) {state = 1;}
LA_out = 0;LB_out = 0;LC_out = 1; LD_out = 0;
LE_out = 0;LF_out = 1;LG_out = 0;LH_out = 1;
case 3:
delay(200);
if ( X1 == 1) {state = 4;}
if ( X2 == 1) {state = 2;}
LE_out = 1;LF_out = 1;LG_out = 0;LH_out = 1;
case 4:
delay(200);
if ( X1 == 1) {state = 5;}
if ( X2 == 1) {state = 3;}
LF_out = 0;LG_out = 0;LH_out = 1;
case 5:
delay(200);
if ( X1 == 1) {state = 6;}
if ( X2 == 1) {state = 4;}
L2_out = 0;L1_out = 1;L0_out = 0;
LA_out = 0;LB_out = 1;LC_out = 0; LD_out = 0;LE_out = 1;
case 6:
delay(200);
if ( X1 == 1) {state = 7;}
if ( X2 == 1) {state = 5;}
LA_out = 0;LB_out = 1;LC_out = 0; LD_out = 0;LE_out = 0;
case 7:
delay(200);
if ( X1 == 1) {state = 8;}
if ( X2 == 1) {state = 6;}
L2_out = 1;L1_out = 0;L0_out = 0;
LA_out = 0;LB_out = 0;LC_out = 0; LD_out = 1;LE_out = 1;
case 8:
delay(200);
if ( X1 == 1) {state = 9;}
if ( X2 == 1) {state = 7;}
case 9:
delay(200);
if ( X1 == 1) {state = 10;}
if ( X2 == 1) {state = 8;}
LA_out = 0;LB_out = 0;LC_out = 0; LD_out = 0;LE_out = 1;
case 10:
delay(200);
if ( X2 == 1) {state = 9;}
LF_out = 0;LG_out = 1;LH_out = 0;
