Button Debouncing Error
int input = 7;
int output = 13;
boolean lastButton = LOW;
boolean ledOn = false;
  pinMode(input, INPUT);
  pinMode(output, OUTPUT);
boolean debounce(boolean buttonState)
  boolean current = digitalRead(input);
  if(buttonState != current)
    delay(5);
  return current;
  boolean state = debounce(digitalRead(input));
  if(state == HIGH && lastButton == LOW)
    ledOn = true;
    lastButton = HIGH;
    digitalWrite(output, HIGH);
  else if(state == HIGH && ledOn)
    ledOn = false;
    lastButton = LOW;
    digitalWrite(output, LOW);
This is the code I am using to toggle an LED. However, it is not toggling properly (button only sometimes turns on/off), even after implementing a debounce function. Is my implementation incorrect?
Do you have an external pull-up or pull-down resistor on pin 7? If not you will either need to enable the internal pull-up by changing:
to:
  pinMode(input, INPUT_PULLUP);
or add an external resistor. See: https://www.arduino.cc/en/Reference/PinMode
How is your button wired? Do you have pull-up or pull-down resistors in place?
5 ms might be a bit short for some buttons to stabilize
