button debouncing for arduino
I found this bit of code:
boolean DebounceSwitch2() {
      int State = 0;
      State=(State<<1) | !RawKeyPressed() | 0xe000;
      if (State==0x000)
            return true;
      return false;
I'm trying to "port" this to Arduino. I'm pretty sure that RawKeyPressed() would be the same as digitalRead() (for my purposes), but exactly what does the whole line mean?
Gabe
AFAICT, that code doesn't work (it will always return false), and even if it did, it seems much too clever for what it's trying to do.
I just posted a new example on the tutorial page: http://www.arduino.cc/en/Tutorial/Switch
It uses a pushbutton as a switch to toggle an LED on and off, and debounces the switch input. Does it help?
I ended up doing almost the exact thing as you:
  newState = digitalRead(inPin);
  if ( (newState != prevState) && (timer + bounceTime < millis()) ){
    timer = millis();    //record time of output
    Serial.print((inPin*10)+newState);
  prevState = newState;
Works great so far with my cheap, cheap button!
Gabe
