Button debouncing
I'm a beginner and I wrote this for debouncing
int led=13,switchp=5;
boolean prevbtn=LOW,ledst=LOW;
pinMode(led,OUTPUT);
pinMode(switchp,INPUT);
int readsw=digitalRead(switchp);
if(readsw!=prevb)
delay(50);
reads=digitalRead(switchp);
if(readsw==HIGH && prevb==LOW)
ledst=!ledst;
prevbtn=HIGH;
prevbtn=digitalRead(switchp);
digitalWrite(led,ledst);
The switch still bounces...may I know why ?
Won't even compile without adding these 2 lines before setup()
byte prevb;
byte reads;
How do you know it still bounces?
For simple switch bounce code, read the switch every 50-100 ms, if there was a state change, do your something based on the current state.
Do not use delay() as sketch progress is frozen in time for that period.
This simple debounce works for me, connect button between pin 5 and GND:
const byte btn = 5,
           ledPin = 13;
unsigned long timeStart;   // unsigned long
unsigned long dbTime = 250;   // debounce time, long for testing,
                     // 10 - 20 typical
bool btnState = false, debouncedState = false;
  pinMode(btn,INPUT_PULLUP);
  pinMode(ledPin,OUTPUT);
  // debounce+++++++++++++++++++++
  if(digitalRead(btn) != btnState)  // they are different!
    btnState = !btnState;           // make them equal
    timeStart = millis();           // restart timer
  if(millis() - timeStart > dbTime) // if not changed for dbTime,
    debouncedState = !btnState; // btnState is valid, use it
  // end debounce+++++++++++++++++
  digitalWrite(ledPin,debouncedState);
Delta_G:
Once your button reads high once your prevb variable is stuck there. You should set it to whatever the button reads on every loop.quote]
I'm doing that in the second last line...
By looking at your code, you are simply toggling the LED state.
You can use this code for debouncing, I have used it many times in my other projects and it works flawlessly. It only sense button press & would not trigger on release.
const byte PIN_SWITCH = 5;
const byte PIN_LED = 13;
byte lastSwitchState = 0;
void setup(){
 pinMode(PIN_SWITCH, INPUT);
 pinMode(PIN_LED, OUTPUT);
void loop(){
  int currentSwitchState = digitalRead(PIN_SWITCH);
  if(currentSwitchState > lastSwitchState){
    toggleLED();
  lastSwitchState = currentSwitchState;
void toggleLED(){
 digitalWrite(PIN_LED, !digitalRead(PIN_LED));
Also, use a .1uF electrolytic cap across the switch for smooth operation.
Thanks for the help everybody....
This fixed it
Delta_G:
If you're debouncing a button then you should only read it once and do all the logic with one reading. Try setting it to equal readsw every time instead of reading it again.
