Button Eagle PCB part
Hello,
I am trying to learn Eagle and print out a simple UI for my Arduino application but I can't find the button schematic on eagle. The button I am using is the one in this tutorial: https://www.arduino.cc/en/tutorial/button.
I found the momentary button from Sparkfun but it doesn't seem to work the same as the schematic only has 2 pins. If I try to use the SparkFun library switch: Momentary Pushbutton Switch - 12mm Square - COM-09190 - SparkFun Electronics, then it only has 1 input which doesn't work when I tried that configuration on the breadboard.
Any idea where I can find the schematic for the Arduino push button?
Thanks
Those are tactile switches so with a bit of Google searching this comes up;
oh nice! Thats what i was looking for thank you!
