Hi there,
I’ve made following class to handle some push buttons.
The output of the “handle” routine is a byte telling me following states of the button: Off, On, On for a long (predefined) time, positive edge and negative edge.
I expect following sequence of states when pressing a button
Off, PosEdge, On, OnLong (when pressed long enough), NegEdge, Off again.
What I get is
Off, On (shortly), PosEdge, On, OnLong (when pressed long enough), NegEdge, Off again.
I can’t see where the first “On” is coming from
Does any of you ?
Thanks for your inputs!
Here is the code (sorry some comment & naming is in Dutch)
Some declarations
enum { ev_Off=0, ev_On, ev_OnLong, ev_PosEdge, ev_NegEdge };
byte _EventRood = 0;
byte _EventZwart = 0;
The class
class ButtonHandler {
public:
// Constructor
ButtonHandler(int Pin, long DelayDebounce, long DelayLongPress);
// Initialization done after construction, to permit static instances
void init();
// Handler, to be called in the loop()
int handle();
protected:
boolean _Latch; // For PosEdge event
long _DelayDebounce; // Setpoint for debounce button
long _DelayLongPress; // Setpoint for long press of button
const int Pin; // Arduino pin number
const long DelayDebounce; // Value to add to millis() when button pressed
const long DelayLongPress; // Value to add to millis() when button pressed
ButtonHandler::ButtonHandler(int p, long ddb, long dlp)
: Pin(p), DelayDebounce(ddb), DelayLongPress(dlp) {
void ButtonHandler::init() {
pinMode(Pin, INPUT_PULLUP);
_DelayDebounce = 0;
_DelayLongPress = 0;
_Latch = false;
int ButtonHandler::handle() {
byte _Event;
// By default set event to "Off"
// Code will then change it when needed
_Event = ev_Off;
if (digitalRead(Pin)) {
// Button NOT pressed = one shot reset variables and set event NegEdge
if (_DelayDebounce > 0) {
_Event = ev_NegEdge; // One shot event NegEdge
_DelayDebounce = 0; // reset variables
_Latch = false;
// Button IS pressed = one shot set delay times
if (_DelayDebounce == 0) {
_DelayDebounce = millis() + DelayDebounce;
_DelayLongPress = millis() + DelayLongPress;
_Latch = false;
// Check debounce time over, need of _Latch for PosEdge event
if (millis() > _DelayDebounce && !_Latch) _Event = ev_PosEdge;
else _Event = ev_On;
if (millis() > _DelayDebounce) _Latch = true;
// Check button pressed for a looooong time
if (millis() > _DelayLongPress) _Event = ev_OnLong;
// Set return value
return _Event;
// Init buttons classes
// ButtonHandler(int pin, long DelayDebonce, long DelayLongPress);
ButtonHandler ToetsRood(P06_ToetsRood, 150, 4000);
ButtonHandler ToetsZwart(P07_ToetsZwart, 150, 4000);
In routine “setup”
// Init buttons
ToetsRood.init();
ToetsZwart.init();
In routine “loop”
// Handle buttons
_EventRood = ToetsRood.handle();
_EventZwart = ToetsZwart.handle();
To evaluate the class I send the status to an LCD, this code is also in the “loop” routine
lcd.setCursor(LCDLine_3, 10);
lcd.print("Rood ");
switch (_EventRood) {
case ev_Off:
lcd.print("Off ");
case ev_On:
lcd.print("On ");
case ev_OnLong:
lcd.print("Long ");
case ev_PosEdge:
lcd.print("PEdge");
delay(750);
case ev_NegEdge:
lcd.print("NEdge");
delay(750);
default:
lcd.print("?????");
lcd.setCursor(LCDLine_4, 9);
lcd.print("Zwart ");
switch (_EventZwart) {
case ev_Off:
lcd.print("Off ");
case ev_On:
lcd.print("On ");
case ev_OnLong:
lcd.print("Long ");
case ev_PosEdge:
lcd.print("PEdge");
delay(750);
case ev_NegEdge:
lcd.print("NEdge");
delay(750);
default:
lcd.print("?????");
