fyrus
September 14, 2021, 1:30pm
1
I use a simple arduino code for button on my sketch, single click, combine click. But anyone know if its can use long press or held function?
uint8_t Rp = 2;
uint8_t Bn1p = 3;
uint8_t Bn2p = 4;
boolean R;
boolean Bn1;
boolean Bn2;
void setup(){
pinMode(Rp, INPUT_PULLUP);
pinMode(Bn1p, INPUT_PULLUP);
pinMode(Bn2p, INPUT_PULLUP;)
void loop(){
readAll();
if (!R) {
Serial.print("click");
if (!R && !Bn1) {
Serial.print("R & Bn1 is pressed");
void readAll() {
Bn1 = digitalRead(Bn1p);
Bn2 = digitalRead(Bn2p);
R = digitalRead(Rp);
Did you forget to post some of the code?
The code that reads the input pins.
Or code that actually compiles, unlike the code you posted
Still doesn't compile, still has no chance of producing any output
Hello
Your sketch needs a simple button handler that takes care about debouncing, interlook and counting of state changes. You may start the for a single button by using C++ instructions enum, struct, array and so on.
system
Closed
January 12, 2022, 2:18pm
8
