So I need some help with a function that does not seem to be working as expected. I am trying to write something that will create a 4 digit pin number string. I want to use 4 buttons to do this: up, down, enter and back. The up and down buttons should increment or decement the digit and pressing enter moves the input position to the next digit. At digit 4 the function exits. Pressing back button erases the pin number and exits the function.
The circuit is 4 push buttons active high connected to PWM 's 2-5.
In the code the pin number is a global string modified by the getPin function with an initial value of "". I am using Bounce2 library to debounce the input. I create 4 bounce objects and set the intervals to 50 on each. The getPin function runs an infinite loop where it reads the buttons and checks the debounced value. It is supposed to exit the loop when the position in the string gets past 4 or when the used presses the back button by calling return. I put serial statements in the code to see what it is doing inside the function. Here is the output when I press the up button once:
Its executing the right code but doing it way more than I would have anticipated. Changing the delay period helps in that it does a few less cycles, but still its is executing more than the number of pushes on the button. If I go to a high enough delay interval it just doesn't respond at all. Suggestions??? Or code if you have had any success with this.
#include <Bounce2.h>
const int buttonDown = 1; //Value expected on pin when button down.
const int interv = 50; //Delay interval for debounce object.
const int pushButtonUp = 2; //Pins used.
const int pushButtonDn = 3;
const int pushButtonEnt = 4; //Enter
const int pushButtonBk = 5; //Back
// Debounced pin objects from library.
Bounce BounceUp = Bounce();
Bounce BounceDn = Bounce();
Bounce BounceEnt = Bounce();
Bounce BounceBk = Bounce();
//Variables
String pinNum; //Global
BounceUp.interval(interv);
BounceDn.interval(interv);
BounceEnt.interval(interv);
BounceBk.interval(interv);
BounceUp.attach(pushButtonUp);
BounceDn.attach(pushButtonDn);
BounceEnt.attach(pushButtonEnt);
BounceBk.attach(pushButtonBk);
pinNum = "";
getPin();
void getPin()
//Function to create pin number...
// Value of pinNum is set within this function.
static int pinLoc = 0; //location within the string pinNum
static int locVal = 0; // numeric value at each digit of pin number.
/* Loop */
while (true)
BounceUp.update();
BounceDn.update();
BounceEnt.update();
BounceBk.update();
if (BounceUp.read() == buttonDown)
//If Up button...
if (locVal < 9)
{locVal ++; //increment digit
Serial.println("Location: "+String(pinLoc) + " Value: "+ String(locVal));
if (BounceDn.read() == buttonDown)
//If Down button...
if (locVal > 0)
{locVal --;} //decrement digit
if (BounceEnt.read() == buttonDown)
//If Enter button...
if (pinLoc < 4)
pinNum = pinNum + String(locVal); //add previuos digit.
pinLoc ++; //increment location
locVal = 0; //Set digit value.
Serial.println("Pin Number: " + pinNum);
// Pin entery complete exit procedure
return;
if (BounceBk.read() == buttonDown)
//If Back button...
pinNum = "";
return;
}//while true
}//getPin()
getPin();
Serial.println("Pin Number: "+pinNum);
