It's almost certain that you won't need interrupts for what you want to do.
If you structure your "read - convert - display" loop correctly, you'll find that there's a simpler way of doing what you want.
Interrupts are more for the sort of situation where you've got something shouting "LOOK AT ME NOW - I'M REALLY IMPORTANT".
On the time scale of temperature changes and screen updates, this is very unlikely.
im doing a delay(1000) before the end of the loop()
should I just decrease the delay and use a
buttonState = digitalRead(buttonPin);
or is there any better way of doing it?
another question,
I have 3 buttons,
I want to do like, if I press two at the same time for like some seconds it will able to change the hour. My code for that is bit ugly, but this is the idea
I'd get rid of the delay, and have your loop poll the clock each time through by calling "millis".
If a second has elapsed, update your clock, if it hasn't, then check your switches.
The delay would be the only reason you'd need an interrupt.
