//ESP32
const int switchStartStopPin = 25;
typedef enum SWITCH
SWITCH_NONE,
SWITCH_1,
SWITCH_2
} switch_t;
switch_t readSwitch(void)
int switchAdcValue = 0;
// Switch connected directly to individual separate pins
if (digitalRead(switchStartStopPin) == LOW) return SWITCH_1;
Serial.println("Switch 1 pressed");
if (digitalRead(switchLfPbPin) == LOW) return SWITCH_2;
return SWITCH_NONE;
What am I missing?
J-M-L
2
The code tags that I added for you?...
The schema of how things are wired and powered?
The rest of the code?
The rest of your code.
A clear description of your problem.
A schematic
Are just three of the things that come to mind
J-M-L
5
how is it wired? as you don't set the pins, they are just INPUT. do you have an external pull-up or pull-down resistor?
system
Closed
6
