Button is never LOW on ESP8266
I didn't fully re-write the sketch, I just changed it up so that the pb might work (with INPUT_PULLUP).
I don't know how the functionality is supposed to flow.
While the @beshur simply can't figure out the N/O and N/C contancts of a Button, how can it be expected form him to have known that every input line of the NodeMCU has a built-in pull-up resistor?
Expecting him to know, would be just commenting on it. Expecting him to not know, is publishing an explanation and ready to run sample code.
Do you expect it to work ?
Have you tried it ?
Ok, thank you for all your suggestions.
I disconnected ESP from the breadboard and GPIO 0 (5) still gives me HIGH.
I changed the MY_BTN pin to 3 and it is always LOW, despite connecting it to 3.3V.
This happens on two different ESP8266's.
As for INPUT_PULLUP I tried it before and it did not work either.
My suspicions are that there is a problem with the wiring and/or the switch
What happens if you remove the switch from the circuit and short 2 jumper wires together as the switch on/off ?
Have you tried the sketch of Post-16? When you face a problem and difficult to solve, then look for a working example and play with it and then correct/adjust your non-functioning project.
This is a way of learning that can't be so easily neglectd.
That's what I did, and I always get HIGH regardless.
I have a problem with this one, since I have a bare ESP8266, not NodeMCU, and I have only two GPIO's accessible.
Looks like it's normal behaviour
another forum link
Tried my sketch with a Wemos D1 mini (reassigned pins to D6 and D7 respectively) and it's fine.
