Anyone have any idea if I’m doing something wrong here? I’m a noob with programming.
I’ve got 16 rgb led strips that change color and a button for each. Each button when pressed turns the strip a solid color. Press it again and it goes back to changing colors. When I press the button it usually changes the color solid right away. When I try to change it back to color-changing by pressing the button again, it doesn’t always work. I have to press it multiple times before it activates correctly.
Again, I’m new to all this programming stuff so I figure maybe what I’m doing is a simple fix.
// output pins
int inMin = 1;
int inMax = 48;
//input pins
const byte button[]= {A0, A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13,
A14, A15};
int buttonPress[16] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
long previousMillis[48] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,};
long interval[48] = {500, 600, 500, 500, 600, 500, 1000};
boolean state1, lastState1 = LOW;
boolean state2, lastState2 = LOW;
boolean state3, lastState3 = LOW;
boolean state4, lastState4 = LOW;
boolean state5, lastState5 = LOW;
boolean state6, lastState6 = LOW;
boolean state7, lastState7 = LOW;
boolean state8, lastState8 = LOW;
boolean state9, lastState9 = LOW;
boolean state10, lastState10 = LOW;
boolean state11, lastState11 = LOW;
boolean state12, lastState12 = LOW;
boolean state13, lastState13 = LOW;
boolean state14, lastState14 = LOW;
boolean state15, lastState15 = LOW;
boolean state16, lastState16 = LOW;
for(int i=inMin; i<=inMax; i++)
pinMode(i, OUTPUT);
for(int i = 0; i<= 16; i++)
pinMode(button[i], INPUT_PULLUP);
//strip 1
state1 = digitalRead(button[0]);
state2 = digitalRead(button[1]);
if(state1 != lastState1)
lastState1 = state1;
if(state1 == HIGH && buttonPress[0] == 0)
digitalWrite(1, HIGH);
digitalWrite(2, LOW);
digitalWrite(3, LOW);
buttonPress[0]++;}
else if (state1 == 0 && buttonPress[0] == 0)
unsigned long currentMillis1 = millis();
if (currentMillis1 - previousMillis[0] >= interval[0]) {
previousMillis[0] = currentMillis1;
digitalWrite(1, !digitalRead(1));
unsigned long currentMillis2 = millis();
if (currentMillis2 - previousMillis[1] >= interval[1]) {
previousMillis[1] = currentMillis2;
digitalWrite(2, !digitalRead(2));}
unsigned long currentMillis3 = millis();
if (currentMillis3 - previousMillis[2] >= interval[2]) {
previousMillis[2] = currentMillis3;
digitalWrite(3, !digitalRead(3));}
else if (state1 == 1 && buttonPress[0] == 1)
{buttonPress[0] = 0;}
//strip 2
if(state2 != lastState2)
lastState2 = state2;
if(state2 == HIGH && buttonPress[1] == 0)
digitalWrite(4, HIGH);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
buttonPress[1]++;}
else if (state2 == 0 && buttonPress[1] == 0)
unsigned long currentMillis4 = millis();
if (currentMillis4 - previousMillis[3] >= interval[3]) {
previousMillis[3] = currentMillis4;
digitalWrite(4, !digitalRead(4));
unsigned long currentMillis5 = millis();
if (currentMillis5 - previousMillis[4] >= interval[4]) {
previousMillis[4] = currentMillis5;
digitalWrite(5, !digitalRead(5));}
unsigned long currentMillis6 = millis();
if (currentMillis6 - previousMillis[2] >= interval[5]) {
previousMillis[2] = currentMillis6;
digitalWrite(6, !digitalRead(6));}
else if (state2 == 1 && buttonPress[1] == 1)
{buttonPress[1] = 0;}
