Hi everyone, I'm working with the button example. I'm trying to figure out when I press the button, it will write the word "ON" on the screen.
Kinda has me stumped right now. Thanks for any info.
Me, too. Hard to tell from your code where the problem is, or from your problem description what is working and what is not working.
Hi!
What button example?
The button example on 0022. I got it outputted to the screen. Here's how I slightly modified the code to get it out on the screen, now the problem I have is when I press the button and "ON" appears on the screen, I don't know how to get "ON" off the screen and return to the "OFF" state.
#include <TFT.h>
Button
Turns on and off a light emitting diode(LED) connected to digital
pin 7, when pressing a pushbutton attached to pin 2.
The circuit:
LED attached from pin 13 to ground
pushbutton attached to pin 2 from +5V
10K resistor attached to pin 2 from ground
Note: on most Arduinos there is already an LED on the board
attached to pin 13.
created 2005
by DojoDave http://www.0j0.org
modified 28 Oct 2010
by Tom Igoe
This example code is in the public domain.
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int TftPin = 7; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
Tft.init();
// initialize the LED pin as an output:
pinMode(TftPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
delay(100);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
Tft.drawString("ON",35,200,2,BLUE);
Tft.drawString("OFF",55,150,2,RED);
Try doing this: Tft.drawString("ON",35,200,2,BLUE);
but using the background colour instead of BLUE.
Thanks, that got it. I used the return function in front of it and it worked like a charm. Thanks everyone for the advice
