Just a warning: this project got tossed on me and i am extremely new to the arduino. I have been working on this all day. I got the lighting sequence down since i can load the project without the button commands and it runs the lighting look once on start up. but i am have a difficult time with the button press.
When you press the button, 2 lights chase in a group of 8, for a duration of time and then go out. Pressing the button again would restart the sequence. With my failed button code, i can only get it to do it once within the first second.
// Define pin to connect Neopixels to
#define PIN 6
//Define pin for pushbutton to connect to
const int BUTTON = 2;
//Initialize value to determine button press HIGH or LOW
int val = 0;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(30, PIN);
uint8_t mode = 0, // Current animation effect
offset = 1; // Position of spinny eyes
uint32_t color1 = 0x006688; // Light Blue
uint32_t color2 = 0x000000; // Black Out
uint32_t prevTime;
pinMode(2, INPUT);
strip.begin();
//strip.setBrightness(85); // 1/3 brightness
prevTime = millis();
val = digitalRead(BUTTON);
uint8_t i;
uint32_t t;
if (val == HIGH) {
switch(mode) {
case 0: // Spinny wheels (8 LEDs on at a time)
for(i=0; i<30; i++) {
uint32_t c = 0;
if(((offset + i) & 6) < 2) c = color1; // 4 pixels on...
// if(((offset + i) & 5) < 2) c = color1; // 4 pixels on...
strip.setPixelColor( i, c); // First eye
// strip.setPixelColor(31-i, c); // Second eye (flipped)
strip.show();
offset++;
delay(30);
case 1: // Black Out
strip.setPixelColor(i, 0);
strip.show();
t = millis();
if((t - prevTime) > 2000) { // Every 8 seconds...
mode++; // Next mode
if(mode > 2) { // End of modes?
mode = 0; // Start modes over
color1 >>= 16; // Next color R->G->B
if(!color1) color1 = 0x000000; // Black Out
for(i=0; i<32; i++) strip.setPixelColor(i, 0);
prevTime = t;
else {
// Black Out
strip.show();
Well i did discover that the "val == HIGH" required the button to be held down to work, so i changed that to low (button release), but i still can't get it to work past it's initial start up. I think need to latch the value to 1 or HIGH at the beginning of my lighting sequence, and then release it afterwards
I don't see anything in particular after going over the content in the link provided about the button. I am trying to implement the lastButtonState as a way to physical release the button and still have the code run out until complete.
Yes. That sound much better. You need to do 2 things.
1st- don't read the HIGH button but the transition from LOW to HIGH like they do in the example;
2nd- in that state you must start the sequence and do that sequence until the end, once you end the sequence you will need to sense that transition from LOW to HIGH to start again.
I just can't get it to start up again when i push the button a second or more times.
#define PIN 6
const int buttonPin = 2;
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
uint32_t prevTime;
pinMode(buttonPin, INPUT);
strip.begin();
buttonState = digitalRead(buttonPin);
uint8_t i;
uint32_t t;
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
else {
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
// turns on the LED every four button pushes by
// checking the modulo of the button push counter.
// the modulo function gives you the remainder of
// the division of two numbers:
if (buttonPushCounter % 4 == 0) {
// Black Out
strip.show();
else {
switch(mode) {
uint32_t c = 0;
if(((offset + i) & 6) < 2) c = color1; // 2 pixels on...
strip.setPixelColor(i, c); // First eye
strip.show();
offset++;
delay(30);
strip.show();
t = millis();
for(i=0; i<132; i++) strip.setPixelColor(i, 0);
prevTime = t;
You only have 2 states (the state 0 and the state 1) but you only change state when the state is greater than 2. That is you will have one state (the state 2 if you want) that the system don't do anything.
What I will do was create a variable, for example turn_on that goes true when the button change his state and goes off at the end of the sequence, for example:
#define PIN 6
uint32_t prevTime;
boolean turn_on=false;
strip.begin();
uint8_t i;
uint32_t t;
turn_on = true;
else {
// Black Out
strip.show();
else {
if (turn_on == true) {
switch(mode) {
uint32_t c = 0;
strip.show();
offset++;
delay(30);
strip.show();
t = millis();
turn_on = false;
prevTime = t;
I changed that portion of the code because it responded faster. originally, i had case 0, case 1, and case 2, i would have used the code you stated, but since i removed the sparkle lighting effect (case 0) and renumbered them, i changed mode to > 1. after the button press with mode > 2, the led lighting took about 1/2 second to start, and as mode > 1 it starts right when the button is pressed.
Now they want to see it fade out, but i don't want to try to figure that out just yet.
