Button problems with industrial pipeline washer timer
I'm attempting to create a timer for a pipeline washer in a dairy barn, it's very similar to the way a washing machine would be. The code just controls a set of relays that operate hot and cold water solenoid, drain plug and vacuum pump. For the most part the code is functional and does what i need it too, but i need it to start at the push of a button and now i just have it looping. I've spent a lot of time trying to figure out what im doing wrong but i haven't made much success. I'm rather new to Arduino so the codes pretty messing but i would appreciate any help i can get.
I tried making the cycle code in a separate void and only had the push button info in the loop but i couldn't get that to work either. Thanks in advance!
Washer_timer_sketch.ino (10.9 KB)
// character LCD example code
// www.hacktronics.com
#include <LiquidCrystal.h>
// Connections:
// rs (LCD pin 4) to Arduino pin 12
// rw (LCD pin 5) to Arduino pin 11
// enable (LCD pin 6) to Arduino pin 10
// LCD pin 15 to Arduino pin 13
// LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
 int backLight = 13;    // pin 13 will control the backlight
 const int buttonPin = A0;  // input pin for pushbutton
 const int buttonPin2 = A1;
int previousButtonState = HIGH;   // for checking the state of a pushButton
#define RELAY1  6   //Controles vacum pump
#define RELAY2  7   //Controles Drain plug
#define RELAY3  8   //Controles Hot solenoid #1
#define RELAY4  9   //Controles Hot solenoid #2
#define RELAY5  1   //Controles Cold solenoid #1
#define RELAY6  0   //Controles Cold solenoid #2
#define RELAY7  8
#define RELAY8  9
#define goButton A1
#define stopButton A3
  // Initialise the Arduino data pins for OUTPUT
  pinMode(RELAY1, OUTPUT);
  pinMode(RELAY2, OUTPUT);
  pinMode(RELAY3, OUTPUT);
  pinMode(RELAY4, OUTPUT);
  pinMode(RELAY5, OUTPUT);
  pinMode(RELAY6, OUTPUT);
  pinMode(RELAY7, OUTPUT);
  pinMode(RELAY8, OUTPUT);
  pinMode(goButton, INPUT);
  digitalWrite(goButton, HIGH);  // activate internal pull-up resistor for this input pin
  pinMode(stopButton, INPUT);
  digitalWrite(stopButton, HIGH);
   digitalWrite(RELAY1,HIGH);          // Turns Relay Off
   digitalWrite(RELAY2,HIGH);          // Turns Relay Off
   digitalWrite(RELAY3,HIGH);          // Turns Relay Off
   digitalWrite(RELAY4,HIGH);          // Turns Relay Off
   digitalWrite(RELAY5,HIGH);          // Turns Relay Off
   digitalWrite(RELAY6,HIGH);          // Turns Relay Off
   digitalWrite(RELAY7,HIGH);          // Turns Relay Off
   digitalWrite(RELAY8,HIGH);          // Turns Relay Off
  pinMode(backLight, OUTPUT);
  digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
  lcd.begin(16,2);              // columns, rows.  use 16,2 for a 16x2 LCD, etc.
  lcd.clear();                  // start with a blank screen
  lcd.setCursor(0,0);           // set cursor to column 0, row 0 (the first row)
  lcd.print("The 182 Washer Timer");    // change this text to whatever you like. keep it clean.
  lcd.setCursor(0,1);           // set cursor to column 0, row 1
  lcd.print("By Brandon Myers");
  delay(2000);                                      // Wait 2 seconds
 // read the pushbutton:
  int buttonState = digitalRead(buttonPin);
  // if the button state has changed,
  if ((buttonState != previousButtonState)
    // and it's currently pressed:
  && (buttonState == LOW)) {
  // if you have a 4 row LCD, uncomment these lines to write to the bottom rows
  // and change the lcd.begin() statement above.
  //lcd.setCursor(0,2);         // set cursor to column 0, row 2
  //lcd.print("Row 3");
  //lcd.setCursor(0,3);         // set cursor to column 0, row 3
  //lcd.print("Row 4");
      //Rinse cycle:
      lcd.print("Rinse Cycle ");    // change this text to whatever you like. keep it clean.
      lcd.print("Initializing");
       digitalWrite(RELAY2,LOW);           // Turns ON Relays 2
   digitalWrite(RELAY3,LOW);           // Turns ON Relays 3
   digitalWrite(RELAY5,LOW);           // Turns ON Relays 5
   delay(145000);                                      // Wait 1:45 m/seconds
      lcd.print("Runing");
   digitalWrite(RELAY1,LOW);           // Turns ON Relays 1
   delay(620000);                                      // Wait 6:20 m/seconds
  lcd.print("Air Cycle");    // change this text to whatever you like. keep it clean.
  lcd.print("And Drain sequince");
  delay(110000);                                      // Wait 1:00 m/seconds
  delay(5000);                                      // Wait 5 seconds
      lcd.print("Wash Cycle ");    // change this text to whatever you like. keep it clean.
        //Wash cycle:
   digitalWrite(RELAY4,LOW);           // Turns ON Relays 4
      lcd.print("Acid Cycle ");    // change this text to whatever you like. keep it clean.
           //Acid cycle:
   digitalWrite(RELAY6,LOW);           // Turns ON Relays 6
  lcd.print("Cycle");    // change this text to whatever you like. keep it clean.
  lcd.print("Has Fineshed");
sorry for the complicated posting, it wouldn't let me post all this at once.
See this
it's repeated a dozen times with no difference but the strings, make a function that does this and reduce your code by a 1000 lines, then it will be easier to read and therefore easier to debug. Cut and paste should be banned from programming editors :slight_smile:
Also I don't think it's necessary to lcd.begin() all the time, I've not used the lcd lib but I would think a single call in setup() would suffice.
And put it in CODE tags as I just did.
Rob
Thanks Rob, at one point i had it as a function but then reverted back to this when it didn't work correctly. Once i get it re-implemented into a function how do i get the push button to properly execute it?
Brandon
With all that code I couldn't see the wood for the trees so I did some refactoring and got rid of most of the obvious comments.
// Connections:
#define VACUUM_PUMP  		6   //Controles vacum pump
#define DRAIN_PLUG  		7   //Controles Drain plug
#define HOT_SOLENOID_1  	8   //Controles Hot solenoid #1
#define HOT_SOLENOID_2  	9   //Controles Hot solenoid #2
#define COLD_SOLENOID_1  	1   //Controles Cold solenoid #1
#define COLD_SOLENOID_2  	0   //Controles Cold solenoid #2
#define RELAY7  8
#define RELAY8  9
#define goButton A1
#define OFF	HIGH
#define ON	LOW
int relay_pins[] =  {
  VACUUM_PUMP,DRAIN_PLUG,HOT_SOLENOID_1,HOT_SOLENOID_2,COLD_SOLENOID_1,COLD_SOLENOID_2,RELAY7,RELAY8};
const int N_RELAYS = sizeof(relay_pins) / sizeof(int);
  for (int i = 0; i < N_RELAYS; i++) {
    pinMode(relay_pins[i], OUTPUT);
    digitalWrite(relay_pins[i],HIGH);
  lcdFunc ("The 182 Washer Timer","By Brandon Myers");
  int buttonState = digitalRead(buttonPin);			// read the pushbutton:
  // if the button state has changed, and it's currently pressed:
  if ((buttonState != previousButtonState) && (buttonState == LOW)) {
    previousButtonState = buttonState;
    doCycle();
void doCycle () {
  lcdFunc("Rinse Cycle ", "Initializing");
  digitalWrite(DRAIN_PLUG,ON);
  digitalWrite(HOT_SOLENOID_1,ON);
  digitalWrite(COLD_SOLENOID_1,ON);
  digitalWrite(COLD_SOLENOID_1,OFF);
  digitalWrite(HOT_SOLENOID_1,OFF);
  delay(2000);
  lcdFunc("Rinse Cycle ", "Runing");
  digitalWrite(VACUUM_PUMP,ON);
  lcdFunc("Air Cycle", "And Drain sequince");
  digitalWrite(DRAIN_PLUG,OFF);
  digitalWrite(VACUUM_PUMP,OFF);
  //Wash cycle:
  lcdFunc("Wash Cycle", "Initializing");
  digitalWrite(HOT_SOLENOID_2,ON);
  digitalWrite(HOT_SOLENOID_2,OFF);
  delay(2000);
  lcdFunc("Wash Cycle", "Runing");
  //Acid cycle:
  lcdFunc("Acid Cycle", "Initializing");
  digitalWrite(COLD_SOLENOID_2,ON);
  digitalWrite(COLD_SOLENOID_2,OFF);          // Turns Relay Off
  lcdFunc("Acid Cycle", "Runing");
  lcdFunc("Cycle", "Has Fineshed");
void lcdFunc(char * str1, char * str2) {
  lcd.print(str1);    			// change this text to whatever you like. keep it clean.
  lcd.print(str2);
Then some things became obvious, like you were printing the wash cycle twice etc but that's not a show stopper.
One problem was that you never updated previousButtonState after you detected a pressed button. I think this would have manifested as you never being about to get a second run of the cycle, was that the problem?
Anyway now that there's a single line in the conditional part of the loop it's easy to print out something to see if that works, then move on to the next problem.
doCycle() is still pretty bad, a table-driven loop would be much better but as a new programmer that would not help I think.
BTW, for testing this sort of thing it's often better to have a define like
#define SEC 1000
then use
delay(SEC * 2);
Now you can change the definition of SEC to say 100 and the code runs 10 times faster.
Rob
brandon-182:
Make an attachment.
How to use this forum
WOW Rob! Thank you, you have no idea how much that helped me!
// Connections:
#define RELAY7  8
#define RELAY8  9
#define goButton A1
#define OFF	HIGH
#define ON	LOW
#define SEC 1000
  delay(SEC*2);                                      // Wait 2 seconds
void loop(){
  rinse();
  drain();
  wash();
  drain();
  acid();
  drain();
void rinse(){
//Rinse cycle:
  delay(SEC*145);                                      // Wait 1:45 m/seconds
  delay(SEC*2);
  delay(SEC*620);                                      // Wait 6:20 m/seconds
void drain(){
  delay(SEC*110);                                 // Wait 1:00 m/seconds
  delay(SEC*5);                                      // Wait 5 seconds
void wash(){
  //Wash cycle:
  delay(SEC*2);
void acid(){
   //Acid cycle:
  delay(SEC*4200);                                      // Wait 4:20 m/seconds
  delay(SEC*100);                                      // Wait 1:00 m/seconds
  lcd.print(str2);
That's what i have now. I was noticing some of my simple errs too right after i posed that last one. I think I made all the changes you suggested, i did have to add lcd.begain for it to format correctly and when i changed the time delays it now nearly skips the rinse fill (Or initialization) maybe i just implemented it wrong. Some of the delays will later be replaced with a level sensor for the water, but i was going to leave that out till the end. For the button it still just takes off on its own (it's not waiting for the button to be pressed). i'll try to read through the link tomorrow that Nick posted, it looks like it might contain some answers.
Try putting an L suffix on your SEC definition:
#define SEC 1000L
Many of your delays are too big to fit in an int - that may be what's causing the misbehavior.
Hey guys thanks again for all the help, currently everything is working just the way i wanted it to including the buttons and the level sensor for the water. Thanks a bunch, if there's anything in the latest code that could be improved don't hesitate to comment.
// Connections:
#define RELAY7  8
#define RELAY8  9
#define goButton A4
#define goButton2 A3
#define fillButton A5
#define OFF	HIGH
#define ON	LOW
#define SEC 1000L
  pinMode (goButton, INPUT);
  pinMode(goButton2, INPUT);
  digitalWrite(goButton2, HIGH);
  pinMode (fillButton, INPUT);
  digitalWrite(fillButton, HIGH);
void loop(){
    if (!digitalRead(goButton)){
  rinse();
  drain();
  wash();
  drain();
  acid();
  drain();
  lcdFunc("Wash Cycle", "Has Finished");}
  if (!digitalRead(goButton2)){ Sanitizer();
  drain(); lcdFunc("Sanitizer Cycle", "Has Finished"); }
void rinse(){
//Rinse cycle:
  delay(SEC*3);
  while (digitalRead(fillButton) != LOW) { } // do nothing{
    if(digitalRead(fillButton) != HIGH) {    //wait for fill sensor
     delay(SEC*2);
     delay(SEC*252);                    // Wait 4:20 m/seconds
     delay(SEC*2);
void drain(){
 delay(SEC*20);
  delay(SEC*100);
void wash(){
  //Wash cycle:
  delay(SEC*3);
     delay(SEC*2);
     delay(SEC*372);
     delay(SEC*10);
    }  // Wait 6:20 m/seconds
void acid(){
   //Acid rinse cycle:
  delay(SEC*3);
     delay(SEC*2);
void Sanitizer(){
   //Sanitizer cycle:
  lcdFunc("Sanitize Cycle", "Initializing");
  delay(SEC*3);
     lcdFunc("Sanitize Cycle", "Runing");
     delay(SEC*2);
  lcd.print(str2);
What do RELAY7 and RELAY8 do? They're set high in setup but after that, there's nothing more done with them.
