I am hoping someone could kindly help with a problem I am having with a project. I am building a simple 4 button motor speed control panel using an Arduino Duemilanove. The motor part works fine and I've followed the guides at - http://www.arduino.cc/en/Tutorial/Button & Arduino Tutorial - Lesson 5 - I believe these examples use a pull up resistor design to set the various pins to read either high or low.
The original circuit works fine. See attached image 1
I now want to change the buttons from the original design to use new buttons as I need to access them in a narrow slot - these 90 degree offset buttons ought to work much better. However when I added the new buttons to my project they didn't work at all.
see attached image 2
I had a good look at the way these new buttons work and it seems they're wired up completely differently inside.
see attached image 3
The old button - all four pins are connected when the button is pressed.
The problem button - only the parallel pins are linked.
I was wondering if anyone could help me sort my circuit design out so that I can use these 90 degree offset buttons. I should point out this is my first electronics project.
Cheers,
Saul
