Button question
Hi All
My first post to this forum. I'm an absolute beginner coding Arduino sketches so would like some advice please. I'm trying to trigger a camera shutter using a sound detector and have managed to create code and a breadboard layout which does just that. My problem is that the sensor is continually listening for noise and each time it hears any it triggers the camera, which is not helpful when I'm trying to set up a shot. What I would like to do is to press a momentary switch which arms the system to listen for noise, fires the camera shutter when it hears the noise then sends the system into inactive mode until the button is pressed again. I have absolutely no idea how to achieve this despite reading countless articles on using buttons, none of which worked on my system. Any help would be much appreciated.
My code is as follows
int flash = 3; //flash is on pin 3
int soundSensor = 4; //sound sensor is on pin 4
int LED = 5; //LED is on pin 5 and is used for testing if the code works
    pinMode(flash, OUTPUT); //sets the flash as an output
    pinMode(soundSensor, INPUT); //sets the sound sensor as an input
    pinMode(LED, OUTPUT); //sets the LED as an output
    int sensorInfo = digitalRead(soundSensor);
    //a variable created for the data taken in by the sound sensor
    digitalWrite(flash, LOW); //start with the flash off
    digitalWrite(soundSensor, HIGH); //Sound sensor ready to detect
    digitalWrite(LED, LOW); //start with the LED off
    if (sensorInfo == LOW) {
        delay (25); //wait for the flash to settle down
        digitalWrite(LED, HIGH); //fires flash
        digitalWrite(flash, HIGH); //turns LED on
        delay (70); //keep the flash on for 70th of a second
        digitalWrite (LED, LOW); //turns LED off
        digitalWrite (flash, LOW); // turns flash off
        delay (2000); //wait 2 seconds for the system to reset
You need a variable, let's call it sensorMayOperate, and all the code you have now in loop() should be inside an IF statement
if (sensorMayOperate == true) {
  // existing code
Then (I think it should be at the bottom of your if (sensorInfo == LOW) you need to insert the line
sensorMayOperate = false;
which will prevent another event.
Then all you need is a little bit of code that sets sensorMayOperate to true when a button is pressed.
...R
Here is example code to show how to toggle the state of a variable (armed) with a push button switch. Only listen for noise when armed is true.
// by C Goulding aka groundFungus
const byte  buttonPin = 4;    // the pin that the pushbutton is attached to
const byte ledPin = 13;       // the pin that the LED is attached to
boolean buttonState = 0;         // current state of the button
boolean lastButtonState = 0;     // previous state of the button
boolean armed = false;
   // initialize the button pin as a input with internal pullup enabled
   pinMode(buttonPin, INPUT_PULLUP);
   // initialize the LED as an output:
   pinMode(ledPin, OUTPUT);
   // initialize serial communication:
   static unsigned long timer = 0;
   unsigned long interval = 50;  // check switch 20 times per second
   if (millis() - timer >= interval)
      timer = millis();
      // read the pushbutton input pin:
      buttonState = digitalRead(buttonPin);
      // compare the new buttonState to its previous state
      if (buttonState != lastButtonState)
         if (buttonState == LOW)
            armed = !armed;  // toggle armed state
            digitalWrite(ledPin, !digitalRead(ledPin));  // toggle led state
            Serial.print("armed condition  ");
            Serial.println(armed);
         // save the current state as the last state,
         //for next time through the loop
         lastButtonState = buttonState;
Thanks for the swift replies. groundFungus I've tried incorporating your code with mine but without much success . I'm sure this is my lack of knowledge and would appreciate it if you could give me a bit more guidance on how to do that. The LED is only there as a circuit checker and indicates that the sound sensor is working and is a visual indicator that the camera has fired.
Many thanks
Why don't you post your changed code and then we can help you get it working?
Steve
This is the incorporated sketch. The sound trigger still detects sound and fires the flash (camera) but the button has no effect.
Thanks for the help.
const byte  buttonPin = 9;    // the pin that the pushbutton is attached to
    timer = millis();
You have everything under one if() statement. Rearrange things along the lines of:
if switch pressed and debounced
set armed=true;
Under a separate section of code:
if(armed == true)
if sensor indicates{
trigger flash
reset armed = false;
How to wire the switch.
