Button + Relay programming question
I've got a super cool butane flamethrower project! The gas is controlled by a solenoid valve and the ignition comes from an arc lighter. the solenoid and arc lighter are both connected to a 2 channel relay and are controlled by a momentary push button.
I am having difficulty programming the logic.
Requirements:
relay channel 1: activated when the button is pushed and deactivated when the button is released
relay channel 2: activated when the button is pushed and deactivated when the button is released BUT will deactivate itself if the button is held for more than 1 second
This is what i have so far it just allows the button to turn on/off both channels
Thanks for your help!
int button_pin = 3;
int relay_arc_pin = 7;
int relay_gas_pin = 11;
pinMode(button_pin, INPUT_PULLUP);
pinMode(relay_arc_pin, OUTPUT);
pinMode(relay_gas_pin, OUTPUT);
if(digitalRead(button_pin) != 0){
digitalWrite(relay_arc_pin, HIGH);
digitalWrite(relay_gas_pin, HIGH);
else{
digitalWrite(relay_arc_pin, LOW);
digitalWrite(relay_gas_pin, LOW);
Add another button (call it button2_pin). Use millis() to time the relay.
I don't see a relay channel 2 in your code. Which relay is relay channel 2? On your relays is activated HIGH or LOW?
Instead of:
I would recommend:
if(digitalRead(button_pin) == HIGH)
Also, please post your code using code tags. You can do that by hitting the </> button above the posting area.
