Button SMS
Hello
Im working on a project to autostart a generator on my cabin.
Iam sending an sms with "start" and the relay switches on, sending "stop" and the relay switch off.
That is working, but i have a feedback switch on my generator to tell me that the generator is running, and im trying to program inn that the arduino will text me back when the generator is running.
The arduino is responding to the switch but the sms wont send. No errors on the serial monitor or the validation.
Can anybody help me?
This is my code (taken bits from different projects)
  This is an example for our Adafruit FONA Cellular Module
  Designed specifically to work with the Adafruit FONA
  ----> http://www.adafruit.com/products/1946
  ----> http://www.adafruit.com/products/1963
  ----> http://www.adafruit.com/products/2468
  ----> http://www.adafruit.com/products/2542
  These cellular modules use TTL Serial to communicate, 2 pins are
  required to interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
// Include library
#include "Adafruit_FONA.h"
#include <SoftwareSerial.h>
// Pins
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
#define RELAY_PIN 7
#define LED_PIN 8
// Lock control
bool lock_state = false;
int init_counter = 0;
int lock_counter = 0;
int lock_delay = 5000;
int state = 0;
const int pin = 12;
// SMS variables
int8_t smsnum = 0;
int8_t smsnum_old = 0;
// Password
String password_on = "start";
String password_off = "stop";
// Buffer for replies
char replybuffer[255];
// Software serial
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Fona
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
// Readline function
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
  // Set output pins
  pinMode(RELAY_PIN, OUTPUT);
  pinMode(LED_PIN, OUTPUT);
  // Start Serial
  while (!Serial);
  Serial.println(F("FONA basic test"));
  Serial.println(F("Initializing....(May take 3 seconds)"));
  // Init FONA
  fonaSerial->begin(4800);
  if (! fona.begin(*fonaSerial)) {
    Serial.println(F("Couldn't find FONA"));
    while(1);
  Serial.println(F("FONA is OK"));
  // Print SIM card IMEI number.
  char imei[15] = {0}; // MUST use a 16 character buffer for IMEI!
  uint8_t imeiLen = fona.getIMEI(imei);
  if (imeiLen > 0) {
    Serial.print("SIM card IMEI: "); Serial.println(imei);
  // Get total number of SMS
  smsnum = fona.getNumSMS();
  // Read last SMS if new message
  if (smsnum > smsnum_old) {
    flushSerial();
    Serial.print(F("Read #"));
    Serial.print(F("\n\rReading SMS #")); Serial.println(smsnum);
    // Retrieve SMS sender address/phone number.
    if (! fona.getSMSSender(smsnum, replybuffer, 250)) {
      Serial.println("Failed!");
    Serial.print(F("FROM: ")); Serial.println(replybuffer);
    // Retrieve SMS value.
    uint16_t smslen;
    if (! fona.readSMS(smsnum, replybuffer, 250, &smslen)) { // pass in buffer and max len!
    Serial.print(F("***** SMS #")); Serial.print(smsnum);
    Serial.print(" ("); Serial.print(smslen); Serial.println(F(") bytes *****"));
    Serial.println(F("*****"));
    // Control the relay depending on the received message
    String message = String(replybuffer);
    // Relay & LED ON
    if (message.indexOf(password_on) > -1) {
      Serial.println("Lock OPEN");
      digitalWrite(RELAY_PIN, HIGH);
      digitalWrite(LED_PIN, HIGH);
      lock_state = true;
      init_counter = millis();
    // Relay & LED OFF
    if (message.indexOf(password_off) > -1) {
      Serial.println("Lock CLOSE");
      digitalWrite(RELAY_PIN, LOW);
      digitalWrite(LED_PIN, LOW);
      lock_state = false;
  // Update timer
  lock_counter = millis();
  // If timer above delay, close the lock again
  if (lock_state == true && (lock_counter - init_counter) > lock_delay) {
    lock_state = false;
  // Update SMS count
  smsnum_old = smsnum;
  // Flush input
  flushSerial();
  while (fona.available()) {
    Serial.write(fona.read());
  // Wait 1 second
  if (digitalRead(pin) == HIGH && state == 0) {
   Serial.print("\r");
   Serial.print("AT+CMGF=1");
   /*Replace XXXXXXXXXX to 10 digit mobile number & ZZ to 2 digit country code*/
   Serial.print("AT+CMGS=\"+4740021234\"\r");
   //The text of the message to be sent.
   Serial.print("Gen running OK");
   Serial.print((char)26);
   state = 1;
 else {
   state = 0;
void flushSerial() {
    while (Serial.available())
    Serial.read();
char readBlocking() {
  while (!Serial.available());
  return Serial.read();
uint16_t readnumber() {
  uint16_t x = 0;
  char c;
  while (! isdigit(c = readBlocking())) {
    //Serial.print(c);
  Serial.print(c);
  x = c - '0';
  while (isdigit(c = readBlocking())) {
    Serial.print(c);
    x *= 10;
    x += c - '0';
  return x;
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout) {
  uint16_t buffidx = 0;
  boolean timeoutvalid = true;
  if (timeout == 0) timeoutvalid = false;
  while (true) {
    if (buffidx > maxbuff) {
      //Serial.println(F("SPACE"));
    while(Serial.available()) {
      char c =  Serial.read();
      //Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
      if (c == '\r') continue;
      if (c == 0xA) {
        if (buffidx == 0)   // the first 0x0A is ignored
          continue;
        timeout = 0;         // the second 0x0A is the end of the line
      buff[buffidx] = c;
      buffidx++;
    if (timeoutvalid && timeout == 0) {
      //Serial.println(F("TIMEOUT"));
    delay(1);
  buff[buffidx] = 0;  // null term
  return buffidx;
In advance, Thank you!
Are you seeing these commands printed to the serial monitor:
together with the general debug messages ?
You have an instance of software serial defined. Maybe you should use that instead if these commands are to be sent to the sms module.
