Button start value?
Hi
If I start the program both relays are ON, but I want that one of them are ON when I start the program. The buttons themselves are working as I want to.
I can somebody tell what to add to the code? Starting values?
My code ise here:
int Relay1 = 5;
int Relay2 = 6;
int buttonApin = 9;
int buttonBpin = 8;
byte leds = 0;
  pinMode(Relay1, OUTPUT);
  pinMode(Relay2, OUTPUT);
  pinMode(buttonApin, INPUT_PULLUP);
  pinMode(buttonBpin, INPUT_PULLUP);
  if (digitalRead(buttonApin) == LOW)
    digitalWrite(Relay1, HIGH);
    digitalWrite(Relay2, LOW);
  if (digitalRead(buttonBpin) == LOW)
    digitalWrite(Relay1, LOW);
    digitalWrite(Relay2, HIGH);
Sorry for my English, it's not my first language.
You need to send one of the relays high in the Setup before you start your loop
int Relay1 = 5;
int Relay2 = 6;
int buttonApin = 9;
int buttonBpin = 8;
byte leds = 0;
haydensmart:
right, but more likely, LOW since the relay pins are pulled up... I'm assuming "Active Low"
digitalWrite(Relay1, LOW); //<<<<<<<<<<<<
Ok. So the code compiles but it is not doing what you want to do.
In your code, you declare the byte data type(8 bits) variable leds = 0; , but you never actually use it.
Also, you are making it a lot more complicated than what is needed. Your current code is just controlling two outputs(5 and 6) with 2 inputs(8 and 9)
Should it be else if() for the second? or does that work?
Finally, you might want to add some delay() s in the if statements.
By the way, for a second language, your english is great!! :slight_smile:
Ethan :slight_smile: :slight_smile: :slight_smile:
Why is it that only the OP, with his first ever post on these forums, used code tags, and everyone else with more experience posted it inline? Setting a bad example.
haydensmart:
Ok it works now! Thank you all :slight_smile:
BulldogLowell:
It doesn't seem to work in LOW.
EQOxx123:
Yes I now deleted the variable leds = 0; and I changed the second to else if(). Thanks
FiveO:
Wish they were all like this.
Ikr
PaulMurrayCbr:
