Hello,
As the input state changes in the state change detection example the led is turned on/off .
Following is my code
int buttonInput = 2;
int led = 13;
int lastButtonState = 0;
int buttonState = 0;
int buttonPushCounter = 0;
pinMode(buttonInput,INPUT_PULLUP);
pinMode(led,OUTPUT);
buttonState=digitalRead(buttonInput);
button();
void button()
if(buttonState !=lastButtonState )
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
while(millis()< currentMillis + 20000)
Serial.println("Inside While");
if(buttonPushCounter>1)
digitalWrite(led,HIGH);
Serial.println("on");
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
digitalWrite(led,LOW);
// Delay a little bit to avoid bouncing
delay(50);
lastButtonState = buttonState;
i want to "on" the led on second count and that should be done in certain period of time, as the code works when buttonPushCounter=1 and it goes in while loop for 20sec but it doesn't detect the second buttonPushCounter , and after 20sec it exits the while loop i want to detect the buttonPushCounter in the given 20sec time
