Button state changing between 1 and 0 constantly
const int button = 2;
int buttonState = 0;
pinMode(button, INPUT);
buttonState = digitalRead(button);
Serial.println(buttonState);
when i press the button, the state is 1 but when i release it, his state changes between 0 and 1
Thank you.
Try
pinMode(button, INPUT_PULLUP);
I tried.
The state stays at 1 even if i press the button
How is your button wired? Is it wired to provide + or GND to the input when pressed?
You wired the button incorrectly, there shouldn't be a resistor in series with it.
Connect one leg of the button to ground, the other to the input pin of the Arduino. Then use INPUT_PULLUP.
Fix the logic to interpret a "low" signal as "pressed", "high" as "released".
Pieter
thank you a lot
PieterP:
Pieter
or what he said. It is way easier to use GND as the active input otherwise if you use + you need an external pull-down resistor.
This post may be useful for you https://forum.arduino.cc/index.php?topic=643756.0
