Button with two mode
Hello, I would like to do a button control but in two modes. I need to do it and intermittently. Change of mode would be done by pressing the button. What am I doing wrong?
int pbuttonPin = 12;// connect output to push button
int relayPin = 2;// Connected to relay (LED)
int przelacznik = 9; // connect switch
int val = 0; // push value from pin 2
int lightON = 0;//light status
int pushed = 0;//push status
int przelaczenie = 0; // switch status
int buttonPresses = 0; // counter for the number of button presses
int lastPressCount = 0; // previous state of the button
// Robojax.com code and video tutorial for push button ON and OFF
pinMode(pbuttonPin, INPUT_PULLUP);
pinMode(relayPin, OUTPUT);
pinMode(przelacznik, INPUT);
void mode_one() {
val = digitalRead(pbuttonPin);// read the push button value
if (val == HIGH && lightON == LOW) {
pushed = 1 - pushed;
delay(100);
lightON = val;
if (pushed == HIGH) {
digitalWrite(relayPin, LOW);
digitalWrite(relayPin, HIGH);
void mode_two() {
if (pbuttonPin == LOW)
if (digitalRead(przelacznik) == LOW) // check if button was pressed
buttonPresses++; // increment buttonPresses count
delay(250); // debounce switch
if (buttonPresses == 2) buttonPresses = 0; //resets button count to zero on second push
{ (lastPressCount != buttonPresses);
if (buttonPresses == 0)
Serial.println("0");
mode_one();
Serial.println("1");
mode_two();
Not using code tags for a start... See How to use the forum.
But next, you do kind of try to make debug statements, what do they tell you?
And two hints for responcive mode selection
  • State change detection
  • non-blocking
A library like Bounce2 can take the heavy work out of your hands for this.
What is this line of code intended to do ?
