Hi I am trying to make an ON and an OFF button to turn my LED strip on or off.
The slider code works great, BUT i cannot figure out for the life of me how to have the button submit, onclick, or POST or whatever it needs to do to affect my slider values.
Please help! I have been struggling for 4 days trying everything I can cut and paste from google. I've even tried loading another sketch in an iframe. I am stuck.
How do I make a 'red' ON (255)' button? with a working example Im sure i could figure out the rest, thanks!
if (type == WebServer::GET)
/* store the HTML in program memory using the P macro */
P(message) =
"<!DOCTYPE html><html><head>"
"<meta charset=\"utf-8\"><meta name=\"apple-mobile-web-app-capable\" content=\"yes\" /><meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge,chrome=1\"><meta name=\"viewport\" content=\"width=device-width, user-scalable=no\">"
"<title>DataCenter RGB LED</title>"
"<link rel=\"stylesheet\" href=\"http://code.jquery.com/mobile/1.0/jquery.mobile-1.0.min.css\" />"
"<script src=\"http://code.jquery.com/jquery-1.6.4.min.js\"></script>"
"<script src=\"http://code.jquery.com/mobile/1.0/jquery.mobile-1.0.min.js\"></script>"
"<style> body, .ui-page { background: black; } .ui-body { padding-bottom: 1.5em; } div.ui-slider { width: 50%; } div.button { width: 20px; } #red, #green, #blue, #redbottom, #greenbottom, #bluebottom, #redroom, #greenroom, #blueroom { display: block; margin: 10px; } #red { background: #f00; } #green { background: #0f0; } #blue { background: #00f; } #redbottom { background: #f00; } #greenbottom { background: #0f0; } #bluebottom { background: #00f; } #redroom { background: #f00; } #greenroom { background: #0f0; } #blueroom { background: #00f; }</style>"
"<script>"
// causes the Arduino to hang quite frequently (more often than Web_AjaxRGB.pde), probably due to the different event triggering the ajax requests
"$(document).ready(function(){ $('#red, #green, #blue').slider; $('#red, #green, #blue').bind( 'change', function(event, ui) { jQuery.ajaxSetup({timeout: 110}); /*not to DDoS the Arduino, you might have to change this to some threshold value that fits your setup*/ var id = $(this).attr('id'); var strength = $(this).val(); if (id == 'red') $.post('/rgb', { red: strength } ); if (id == 'green') $.post('/rgb', { green: strength } ); if (id == 'blue') $.post('/rgb', { blue: strength } ); });});"
"$(document).ready(function(){ $('#redbottom, #greenbottom, #bluebottom').slider; $('#redbottom, #greenbottom, #bluebottom').bind( 'change', function(event, ui) { jQuery.ajaxSetup({timeout: 110}); /*not to DDoS the Arduino, you might have to change this to some threshold value that fits your setup*/ var id = $(this).attr('id'); var strength = $(this).val(); if (id == 'redbottom') $.post('/rgb', { redbottom: strength } ); if (id == 'greenbottom') $.post('/rgb', { greenbottom: strength } ); if (id == 'bluebottom') $.post('/rgb', { bluebottom: strength } ); });});"
"$(document).ready(function(){ $('#redroom, #greenroom, #blueroom').slider; $('#redroom, #greenroom, #blueroom').bind( 'change', function(event, ui) { jQuery.ajaxSetup({timeout: 110}); /*not to DDoS the Arduino, you might have to change this to some threshold value that fits your setup*/ var id = $(this).attr('id'); var strength = $(this).val(); if (id == 'redroom') $.post('/rgb', { redroom: strength } ); if (id == 'greenroom') $.post('/rgb', { greenroom: strength } ); if (id == 'blueroom') $.post('/rgb', { blueroom: strength } ); });});"
"</script>"
"</head>"
"<body>"
"<div data-role=\"header\" data-position=\"inline\"><h1>7 Argonaut</h1></div>"
"<div data-role=\"header\" data-position=\"inline\"><h1>Upper LEDs</h1></div>"
"<div class=\"ui-body ui-body-a\">"
"<input type=\"range\" name=\"slider\" id=\"red\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"green\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"blue\" value=\"0\" min=\"0\" max=\"255\" />"
"<div data-role=\"header\" data-position=\"inline\"><h1>Lower LEDs</h1></div>"
"<input type=\"range\" name=\"slider\" id=\"redbottom\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"greenbottom\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"bluebottom\" value=\"0\" min=\"0\" max=\"255\" />"
"<div data-role=\"header\" data-position=\"inline\"><h1>Ceiling LEDs</h1></div>"
"<input type=\"range\" name=\"slider\" id=\"redroom\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"greenroom\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"blueroom\" value=\"0\" min=\"0\" max=\"255\" />"
"</div>"
"<table width='200' border='1' align='center'>"
"<form action='/rgb' method='POST'>"
"<button value='255' name='redbon'>ON</button>"
"<button value='0' name='redboff'>OFF</button>"
"</form>"
i guess i need an ajax function?
