I am attempting to toggle between a simple "strip.color" found within Examples> Adafruit Noepixel>buttoncycler and the "Centerfire"sketch found at:
The problem I am having is that while I can get either the sketch to work by themselves I have been unable to successfully include the Centerfire sketch as a toggle item. The setup values seem to be consistent between them.
My thought was that I should be able to somehow replace the "case3:" to "toggle" over to the centerfire sketch. when the button is depressed... its probably something simple but epic fail for me.
Any help,direction appreciated.
The sketches are included below. The buttoncycler was edited to a much shorter version and verified working. The CenterFire sketch has only pin call out and pin location changes for consistancy between the sketches.
Any help direction appreciated.
//buttoncycler_short
//Cycle between Adafruit Neopixel>buttoncycler control of all on strip and centerfire sketch
// Simple demonstration on using an input device to trigger changes on your
// NeoPixels. Wire a momentary push button to connect from ground to a
// digital IO pin. When the button is pressed it will change to a new pixel
// animation. Initial state has all pixels off -- press the button once to
// start the first animation. As written, the button does not interrupt an
// animation in-progress, it works only when idle.
// Digital IO pin connected to the button. This will be driven with a
// pull-up resistor so the switch pulls the pin to ground momentarily.
// On a high -> low transition the button press logic will execute.
#define BUTTON_PIN 6
#define PIXEL_PIN 2 // Digital IO pin connected to the NeoPixels.
#define NUM_LEDS 10 // Number of NeoPixels 70 when working
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(NUM_LEDS, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
boolean oldState = HIGH;
int mode = 0; // Currently-active animation mode, 0-9
pinMode(BUTTON_PIN, INPUT_PULLUP);
strip.begin(); // Initialize NeoPixel strip object (REQUIRED)
strip.show(); // Initialize all pixels to 'off'
// Get current button state.
boolean newState = digitalRead(BUTTON_PIN);
// Check if state changed from high to low (button press).
if((newState == LOW) && (oldState == HIGH)) {
// Short delay to debounce button.
delay(20);
// Check if button is still low after debounce.
if(newState == LOW) { // Yes, still low
if(++mode > 8) mode = 0; // Advance to next mode, wrap around after #8
switch(mode) { // Start the new animation...
case 0:
colorWipe(strip.Color( 0, 0, 0), 50); // Black/off
case 1:
colorWipe(strip.Color(240, 240, 240), 240); // White
case 2:
colorWipe(strip.Color( 0, 255, 0), 50); // Green
case 3:
colorWipe(strip.Color( 0, 0, 255), 50); // Blue
// Set the last-read button state to the old state.
oldState = newState;
// Fill strip pixels one after another with a color. Strip is NOT cleared
// first; anything there will be covered pixel by pixel. Pass in color
// (as a single 'packed' 32-bit value, which you can get by calling
// strip.Color(red, green, blue) as shown in the loop() function above),
// and a delay time (in milliseconds) between pixels.
void colorWipe(uint32_t color, int wait) {
for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
strip.setPixelColor(i, color); // Set pixel's color (in RAM)
strip.show(); // Update strip to match
delay(wait); // Pause for a moment
Centerfire Sketch to be toggled:
//https://forum.arduino.cc/t/help-starting-fire-code-in-middle-of-strip-going-out-to-both-ends/575890
#define NUM_LEDS 10 // set to an even number
#define MIRROR 5 // set to 1/2 of the LED count
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
Fire(55,120,15,1);
void Fire(int Cooling, int Sparking, int SpeedDelay, int Mirror) {
static byte heat[NUM_LEDS];
int cooldown;
// Step 1. Cool down every cell a little
for( int i = 0; i < NUM_LEDS; i++) {
cooldown = random(0, ((Cooling * 10) / NUM_LEDS) + 2);
if(cooldown>heat[i]) {
heat[i]=0;
heat[i]=heat[i]-cooldown;
// Step 2. Heat from each cell drifts 'up' and diffuses a little
for( int k= NUM_LEDS - 1; k >= 2; k--) {
heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2]) / 3;
// Step 3. Randomly ignite new 'sparks' near the bottom
if( random(255) < Sparking ) {
int y = random(7);
heat[y] = heat[y] + random(160,255);
//heat[y] = random(160,255);
// Step 4. Convert heat to LED colors
for( int j = 0; j < NUM_LEDS - MIRROR; j++) {
setPixelHeatColor(j+MIRROR, heat[j] );
setPixelHeatColor(MIRROR-j, heat[j] );
showStrip();
delay(SpeedDelay);
void setPixelHeatColor (int Pixel, byte temperature) {
// Scale 'heat' down from 0-255 to 0-191
byte t192 = round((temperature/255.0)*191);
// calculate ramp up from
byte heatramp = t192 & 0x3F; // 0..63
heatramp <<= 2; // scale up to 0..252
// figure out which third of the spectrum we're in:
if( t192 > 0x80) { // hottest
setPixel(Pixel, 255, 255, heatramp);
} else if( t192 > 0x40 ) { // middle
setPixel(Pixel, 255, heatramp, 0);
} else { // coolest
setPixel(Pixel, heatramp, 0, 0);
void showStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H
// NeoPixel
strip.show();
#endif
#ifndef ADAFRUIT_NEOPIXEL_H
// FastLED
FastLED.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
// NeoPixel
strip.setPixelColor(Pixel, strip.Color(red, green, blue));
#endif
// FastLED
leds[Pixel].r = red;
leds[Pixel].g = green;
leds[Pixel].b = blue;
#endif
void setAll(byte red, byte green, byte blue) {
for(int i = 0; i < NUM_LEDS; i++ ) {
setPixel(i, red, green, blue);
showStrip();
