Hello, I'm trying to make a buttoncycler code for my LED's, everything works fine, but the problem is with Rainbow loop, in buttoncycler Rainbow runs only one full cycle and that's it, but when I launch Rainbow as separate it works fine without stopping, I just don't know what could be the problem.
THE CODE:
#ifdef __AVR__
#include <avr/power.h>
#endif
#define BUTTON_PIN 5
#define PIXEL_PIN 8
#define PIXEL_COUNT 16
Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, NEO_RGB + NEO_KHZ800);
boolean oldState = HIGH;
int mode = 0;
pinMode(BUTTON_PIN, INPUT_PULLUP);
strip.begin(); // Initialize NeoPixel strip object (REQUIRED)
strip.show(); // Initialize all pixels to 'off'
// Get current button state.
boolean newState = digitalRead(BUTTON_PIN);
if((newState == LOW) && (oldState == HIGH)) {
// Short delay to debounce button.
delay(20);
// Check if button is still low after debounce.
if(newState == LOW) { // Yes, still low
if(++mode > 5) mode = 0; // Advance to next mode, wrap around after #8
switch(mode) { // Start the new animation...
case 0:
colorWipe(strip.Color( 0, 0, 0), 50); // Black/off
case 1:
colorWipe(strip.Color(255, 0, 0), 50); // Red
case 2:
colorWipe(strip.Color( 0, 255, 0), 50); // Green
case 3:
colorWipe(strip.Color( 0, 0, 255), 50); // Blue
case 4:
colorWipe(strip.Color(127, 127, 127), 50); // White
case 5:
rainbow(55);
// Set the last-read button state to the old state.
oldState = newState;
void colorWipe(uint32_t color, int wait) {
for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
strip.setPixelColor(i, color); // Set pixel's color (in RAM)
strip.show(); // Update strip to match
delay(wait); // Pause for a moment
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
